2003n s type fuel pump
Old Dec 4, 2016 | 10:13 AM
capthale's Avatar
Default 2003n s type fuel pump
I recently swapped fuel pump, all relays and fuses have been checked. now when I try and start car...nothing. I don't hear the fuel pump kick on to prime system. was told that the ecu needed to be reprogrammed to recognize new fuel pump. HELP!
Old Dec 4, 2016 | 11:28 AM
JagV8's Avatar
No reprogramming needed.
If it doesn't run at all you're looking at fuse, relay, wiring, connector, cut off, etc. Start with the circuit diagram & workshop manual if you want to DIY.
Old Dec 4, 2016 | 03:54 PM
capthale's Avatar
Thanks, I checked all fuses. Now battery is extremely low. Ill charge it and try again. Will post results in the near future.
Old Dec 4, 2016 | 05:00 PM
JagV8's Avatar
Forget doing any diagnosing with a less than great battery. Just asking for false problems all due to it.
Old Dec 5, 2016 | 10:08 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
+1
Battery must be fully charged when troubleshooting.
