2004 S-Type, 4.2 - Front wire harness/fog light assy broken (w/pics)
Old Aug 20, 2009 | 01:05 AM
bcave's Avatar
Default 2004 S-Type, 4.2 - Front wire harness/fog light assy broken (w/pics)
I just purchased a 2004 S-Type. The right side turn/side marker do not work due to a broken wiring harness at the left fog light assembly. The back of the fog light assembly is broken as well. I need some advice for repair.
I can purchase the fog light assembly here for $99.18. I can find some spare wire to splice this with and wire wrap to protect it. I think the wires are color-coded and I should be able to tell what goes where.
The problem is the connector that goes on the end of the fog lamp assembly is MIA. I could not find the part online.
1) Does my method of repair sound like I am going in the right direction (are the wires color-coded)?
2) Does anyone know where I might find the connector that is wired to the harness at this point (socket that the bulb plugs in to)?
I have included some pics showing the left side (damaged) and the right side (intact).
Thanks in advance for your replies.
Right Side, Intact (for reference):
Old Aug 20, 2009 | 01:59 AM
JagV8's Avatar
You might get one from a wreck. Or, the electrical guide (part of JTIS which you can google) should confirm which pin is which (though they're likely the same left & right). (Mine's an R, so is likely different.)
stanjag
Dec 29, 2024 08:26 PM
rudelover2
Sep 11, 2015 08:53 PM
Aranon
Sep 3, 2015 07:56 PM
ControlIssues
Sep 3, 2015 07:38 PM
Aranon
Sep 1, 2015 01:00 PM
