2004 s-type alternator problem -please help
Old Mar 29, 2010 | 08:33 PM
Thermo's Avatar
Veteran: Navy
SGB, first, using a multimeter, confirm a bad output from the alternator by measuring the voltage across the battery. If the alternator is functioning properly, you should be getting a voltage between 13.8 and 14.4 VDC. If you are getting this voltage, then let me know and we will take actions from that point.
If you don't get 12 VDC on the white/red wire, then that is indicating a bad wire between the alternator and the ECM (engine control module) or a bad ECM.
If your voltage is down around 12.5 VDC, then that is confirming the alternator is not functioning at all. Next, get access to the alternator and find the green/orange wire and see if you have 12 VDC on that wire with the motor running. If no, then check fuse F15 (5 amp). If you even think the fuse could be bad, replace with a new fuse. If yes, then you have confirmed that fuse F15 is good. Next, measure the voltage on the white/red wire going to the alternator. Are you getting something very close to 12 VDC? if yes, then this is confirming a bad alternator or you have an issue with the wire running between the alternator output and the starter. You can confirm between the two by measuring the voltage on the output of the alternator. If you get 14.4 VDC (or something near), the alternator is good and the wire is bad, you get something under 13.8 VDC, bad alternator.
That should hopefully get you down to the point of finding a bad component and being able to fix it. Please note that the battery should be recharged before connecting up the new alternator as the alternator can be overloaded and be damaged if you initially attempt to run the car with a drained battery.
kelliott
May 31, 2022 05:26 PM
Numwen
Sep 6, 2015 12:30 AM
obwoodie
Sep 3, 2015 07:45 PM
pocketrocket
Sep 3, 2015 07:44 PM
laserguy
Sep 3, 2015 02:02 PM
