2004 STR-Rear marker light install
Old Jan 3, 2013 | 10:42 PM
FJG123's Avatar
Default 2004 STR-Rear marker light install
Hello there
My rear marker lights that fit in the sides of the the car in the lower area just above the bumper are broken.Small red lights with plastic clips.it seems these plastic clips seem to break.
Can anyone tell me how to change them as I have new ones from Jag.
Thanks.Fitz
Old Jan 4, 2013 | 05:33 AM
joycesjag's Avatar
This may help:
https://www.jaguarforums.com/forum/s...-change-28786/
Old Jan 5, 2013 | 10:15 AM
NvmyJag's Avatar
I just removed mine and the only thing you need to do is push down on the entire lense with both hands and carefully wiggle them out top first.
Look @ post #2:
https://www.jaguarforums.com/forum/s...removal-35098/
Old Jan 6, 2013 | 03:34 PM
FJG123's Avatar
Default Hi there
Thank you everyone
Does anyone know the trick of removing the power connector to the white bulb section?
Fitz
Old Jan 7, 2013 | 07:09 PM
GaryinOregon's Avatar
remove the metal C-shaped clip that binds the two together. I had to use a small pliers to do that. If you don't you will end up breaking it into pieces. Hope this helps. I just replaced a burnt out bulb last week.
Old Jan 7, 2013 | 08:32 PM
NvmyJag's Avatar
I found using a set of long nose pliers made it much easier and pry up on one side. I had to use too much man power with the smaller pliers . Once you get the metal clip off you can turn the white bulb holder 1/4 turn and pull out.
When you replace the bulb check to ensure the housing isn't cracked from the heat of the bulb. Once it cracks, it will allow water to get into the bulb socket and keep killing bulbs. New ones are only $25.00 so if your housing is cracked buy a new one.
Jpav27
Jul 31, 2022 06:43 AM
Dz1rfj
Jul 17, 2018 10:29 AM
afterburner1
Dec 16, 2015 12:12 AM
redrover41
23
Sep 25, 2015 01:33 PM
Numwen
Sep 6, 2015 12:30 AM
