2004 Stype V8
Old Aug 20, 2015 | 01:47 PM
Chris Cathcart's Avatar
Default 2004 Stype V8
Hi all-
Looking for some ideas here. My jag has had a lot of
Issues over the past several months. Gear box faults, etc. it has 88k miles on it. However, a few days ago I was reversing out of my drive way when I got a park code and a restricted performance and I couldn't get it out of park. Took to the local ford dealer who showed a code of PR0750. They are saying some sort of sensor shift and I need a new transmission. 2900.00 for a used one installed. Thoughts?
Old Aug 20, 2015 | 04:04 PM
pab's Avatar
pab
Start by getting a new battery. These cars are very prone to phantom codes when the battery begins to fail.
Jaguar - it's not an automobile, it's a Motorcar
Current: '08 S-Type 4.2 "Satin Edition" (250.06 hp / 259.67 torque)
Past: '05 X-Type 3.0/auto Jaguar Racing Green
JagV8's Avatar
First, it can't be PR.... as R isn't valid, so maybe it's P0750.
We see few faults on your model so step back and take some time.
You really want to be able to do simple DIY or find a cheap and practical shop.
One thing we do see is loose/missing bolt(s) on the trans side for the shifter cable. May be that.
We OFTEN see weird faults due to a failing battery. Easily #1 suspect. Easy DIY and quite cheap to replace (especially if its age is uncertain).
You REALLY don't want to be at a Ford dealer!!
Old Aug 20, 2015 | 04:07 PM
pab's Avatar
pab
Wow, JagV8 and I simultaneously picked a bad battery
You dreamed of a big star
he played a mean guitar
He loved to drive his Jaguar...
So welcome to the machine
tbird6's Avatar
Can you do your own work?
If not I would get rid of the car now.
Old Aug 20, 2015 | 04:51 PM
Mikey's Avatar
A Ford dealer wouldn't have any more clue than a kid working across the street at Burger King. If you can't DIY, at least find a Jag specialist.
Old Aug 20, 2015 | 07:36 PM
ZenFly's Avatar
I see trans on ebay for $1000 and less with a warranty..
http://www.ebay.com/itm/03-04-Jaguar...a6749d&vxp=mtr
Automatic Transmission Removed from A 2003 Jaguar XJ8 4 2L with 58 502 Miles | eBay
Old Aug 20, 2015 | 09:26 PM
davidladewig's Avatar
Do you happen to know what automatic transmission you have? Mine is a Ford 5R55N. I spoke to an expert in transmissions and he told me this is a fine tranny and most of the models in this era are really good. Tread cautiously with the Ford dealer overpriced parts. Get a battery for $135 or so and have the linkage bolts checked. You have too low a mileage for this much wrong, as a rule.
Old Aug 21, 2015 | 04:39 AM
JagV8's Avatar
It's a ZF 6HP26 but for goodness sake don't replace it at this stage!!
robbing
Mar 5, 2024 10:51 AM
kingdom worker
Nov 14, 2020 03:47 PM
MrWhite
Oct 1, 2015 01:43 AM
millertic
Sep 30, 2015 08:11 PM
Paulie710
Sep 28, 2015 03:49 PM
