2005 S-Type Gearbox Fault Update
Old Dec 11, 2013 | 04:48 PM
Originally Posted by Lt0302
do you have a source on the island that would have all the connectors available for the engine harness for 05 Jaguar S type with 4.2 NA?
Have you checked the Ford catalogue? Motorcraft® Wiring Sets for Ford, Lincoln and Mercury Vehicles | The Official Ford Parts Site | FordParts.com
That's where I got a IMT connector recently. (In stock at Sanderson Ford)
Old Dec 11, 2013 | 05:03 PM
Lt0302's Avatar
Default Thank you
On it
Old Dec 11, 2013 | 07:32 PM
Raspjaguar's Avatar
Default Me too
'05 s-type, 4.2 - on my way home from work this evening and the Gearbox Fault light came on and it would not shift out of first. After getting the car home, I turned it off, restarted, the light did not return and it shifts o.k. - maybe a little balky, maybe. Is the fact that it was ok on restart indicitive of an electric versus hardware problem(i.e. torque converter) or am I looking at a major expense and if so, how much, usually?
Thanks!
Old Dec 11, 2013 | 09:53 PM
campaign308's Avatar
Just purchased the OBD II reader Norri suggested, will read codes once it arrives, and see where I'll go from their. Going to check fuses once I get home tomorrow as I believe my gearbox fault issue is electrical because after I took it to an auto carwash one night everything went downhill from the next day till now unfortunately
Thanks to everyone trying to help one way or another ! Greatly appreciated
Old Dec 12, 2013 | 02:17 AM
JagV8's Avatar
Maybe a failing battery? Reading codes is sensible.
Old Dec 13, 2013 | 08:01 AM
Purchased a new battery after a few gearbox fault messages came up and it didn't resolve
Old Dec 13, 2013 | 09:59 AM
ONEsicJAG's Avatar
What is? Enlighten me!
Just an idea.. it is very possible someone whom has worked on your car before you owned it was very aggressive with the wire connections while removing parts. Pulling on the wires to get connectors apart, stretching them beyond a reasonable point, bending and twisting them out of the way. Just an idea..
Old Dec 13, 2013 | 10:49 AM
  #28
Lt0302's Avatar
Default Possible
Car was owned by my grandfather and all work was performed at the dealer.
Coils were the only "electrical" work the car saw till I had to do the headgasket....by then all the wires were brittle...I think I need to post a few pictures
Old Dec 13, 2013 | 11:59 AM
JagV8's Avatar
By no means every dealer (each is a franchise) is beyond reproach.
Old Dec 13, 2013 | 03:07 PM
  #30
ONEsicJAG's Avatar
Sorry for the confusion, we need not discuss this further.. I was under the impression this was your thread. Guess I should have did a little research ..before I opened my mouth.
Calvin
Old Dec 30, 2019 | 07:58 AM
  #31
Sifiso Michion Radebe's Avatar
After the rain my 2005 jaguar s type 3.0 v6 went to restricted mood until removing the engine cover and pulled out one by one coil plugs on the left hand side of the engine. All 3coils was full of water clean and seal the area also cleaned the ecm connector take out the clogged muddy on the water drain cleared. The water got into the colis because somehow the round coil hole changes the shapes and coil does not fit properly after all that cleaning starts the car of restricted mood and show the gearbox faulty massage and rough changing stop and starting again that happened 3 times after my car was back to smooth mood try to clean yours
Old Dec 30, 2019 | 09:04 AM
  #32
S-Type Owner's Avatar
This is a very old thread and OP (original poster) has not been active on the forum since October 2014, so hopefully his car is sorted by now...
cissdm
May 3, 2016 06:02 AM
caveforce
38
Nov 16, 2015 10:19 AM
BSM
Mark V - X 420G
Sep 14, 2015 08:35 AM
veffremov
Sep 9, 2015 01:23 AM
pnwrs2000
Sep 3, 2015 11:55 AM
