2005 S Type won't shift into any gear
A while back when my battery drained down I couldn't move my gearshift lever at all. Once the battery was recharged it shifted fine. Last night my son spilled a diet soda all over the console and I know some went down into the shifter mechanism. THe battery seems to be charged but the lever isn't shiftin at all again. Any ideas?
bfsgross (12-15-2012)
Check other fuses.
And relays, maybe.
Safety interlocks tend to be simple-minded so they're.... safe. You're likely looking for something very simple.
On the later cars (2002.5MY-on) various of the gearbox-area lights are driven from a module (on the CAN bus) but I'm fairly sure they are just lights i.e. that's all the module does. It would be mildly annoying if it broke but I think that's all. A module is NOT a simple-minded thing so is not likely your problem.
And relays, maybe.
No shift module
This means the shift interlock is a simple switch to solenoid actuated (no module) actuated interlock device. Check for power eminating from harness going to interlock solenoid. If no power, then fuse/relay issue.
