2005 STR SC with 130000
Old Jan 11, 2016 | 01:36 PM
Carlg07's Avatar
Default 2005 STR SC with 130000
finally after several days of delay was able to get my 05 running. Required new battery. Bad water leak from front its too cold to start disassembling more of a spring job. I have a odb2 which gave me two codes PO 456 and PO 1643. it has a bad gas cap so that should take care of the 456. Please any information on the 1643 would be helpful at least for the research end.
As far as the leak with the volume its probably a bad hose,thermostat or water pump. started to push it out with higher RPMs.
thanks in advance.
Old Jan 11, 2016 | 02:06 PM
JagV8's Avatar
Do yourself a favour and get either the codes PDF for your car or better the workshop manual (which includes it) - both free downloads.
P1643 is in there and with a dubious battery may well be false - or is it coming up often?
Old Jan 11, 2016 | 02:22 PM
Carlg07's Avatar
Thanx will do
hawaiianjag
Dec 20, 2020 05:01 PM
Johnken
Jul 12, 2016 02:45 PM
jmbpharris
Jan 5, 2016 04:52 PM
scooby73
Dec 28, 2015 12:41 PM
kamalislamof
Dec 15, 2015 09:06 PM
