2006 S-Type 3.0 - Evaporative System Drive Cycle Test (TSB 021210)
Old Apr 30, 2018 | 02:00 PM
ags's Avatar
ags
Default 2006 S-Type 3.0 - Evaporative System Drive Cycle Test (TSB 021210)
I recently did a lot of work on my 2006 S-Type 3.0 and it runs great. However, I need to complete the evaporative system drive cycle so the vehicle can be inspected for emissions. On-board diagnostics guide for my car (attached in case someone needs it...) refers TSB 021210 for evaporative system monitor drive cycle info.
I do not have access to TSB021210, but I did come across the following list of steps posted on https://www.obd-codes.com/jaguar-drive-cycle:
Could someone familiar with the procedure comment of whether above steps are relevant to 2006 S-Type 3.0? If not, perhaps someone has a copy of TSB 021210 They can share?
Any help is greatly appreciated.
Old Apr 30, 2018 | 03:14 PM
JagV8's Avatar
That does not look like a Jaguar TSB ref.
I would not clear DTCs as it clears all OBD monitors and sets you back to step zero.
Two threads essentially about the same issue are confusing!!!
The other being https://www.jaguarforums.com/forum/s...ad-ecm-199985/
Old Apr 30, 2018 | 05:10 PM
abonano's Avatar
Laymens terms:
Fuel level between 1/4 to 3/4 full. 1/2 tank ideal.
Engine must not been run for previous 10 - 12 hours and must be cold.
Ambient temp must be above 40 deg F.
Start car and immediately drive.
Get to a long stretch of road preferably a highway.
Once engine is at temp drive steady between 45 - 55mph for about 3 - 5 mins.
Then increase speed to 55 - 65 mph. Keeping throttle steady (no cruise control) for another 10 - 12 mins.
Come to a stop when conditions allow, let engine idle for 60 seconds then shut car off.
Old May 2, 2018 | 04:13 PM
ags's Avatar
ags
abanano - thanks.
Old May 2, 2018 | 05:42 PM
Mikey's Avatar
Link to the referenced TSB
https://www.jaguarforums.com/forum/a...b_021210-1.pdf
Old May 5, 2018 | 06:47 AM
JagV8's Avatar
Ah yes, sorry. It's a most odd TSB ref.
Old May 6, 2018 | 07:22 AM
ags's Avatar
ags
Originally Posted by Mikey
wow, thank you!
Rogelio Serrano
Sep 11, 2018 04:04 AM
studeb
Sep 13, 2017 11:20 PM
rainbowboy
Apr 14, 2014 09:00 PM
slbrooks
Aug 2, 2012 04:41 PM
lg611
Jul 29, 2011 01:45 PM
