2006 S Type Bad Deal
Old Jun 2, 2012 | 02:45 PM
Biggbore's Avatar
Default 2006 S Type Bad Deal
Hello, I just bought 2006 S Type w/37000 mls for $13200 , I 'm now buying A/C compressor & now the door locks won't lock!! They lock but unlock right after , checked all doors,hood & trunk . The shine is dimming Please advise!!
Old Jun 2, 2012 | 03:23 PM
joycesjag's Avatar
Bigg, I moved your thread to its own for better exposer.
There is a TSB on here that could save you alot of money on the AC compressor.
I am pushed for time but someone will post it it soon, or YOU can always search for it.
Old Jun 2, 2012 | 03:53 PM
Ha! we must have been moving the thread at the same time!
You won Rick.
Here's the TSB, the door lock problem rings a bell, worth a search I'd say, use google and follow JagV8s advice in the help & suggestions section.
File Type: pdf
Old Jun 2, 2012 | 04:30 PM
joycesjag's Avatar
no winning norri . I wondered what the heII was going on .
Thanks for posting the TSB
Old Jun 2, 2012 | 07:51 PM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
Re: door locks, etc. Check your battery, if it's original, it most likely will need replacing. Get a hygrometer from any auto supply and check each cell, may have one or more weak ones.
Good luck.
Old Jun 3, 2012 | 04:09 PM
cliff328's Avatar
Default This TSB is a bit confusing...
It appears to have you remove the valve, then the spring.
In the replacement mode, you put the valve in first, then
the spring! Can this be correct?
Cliff
Old Jun 3, 2012 | 04:17 PM
Biggbore's Avatar
Thumbs up 2006 S Type
Yep !! Low bat , Man am I glad I stopped by here first !! THANKS GUYS!!
Old Jun 3, 2012 | 05:13 PM
JagV8's Avatar
It's such a great fix good to know.
Old Jun 3, 2012 | 05:26 PM
Cliff
Yes, you are effictively disabling the valve. The newer units don't have the valve.
Old Jun 9, 2012 | 04:46 PM
Biggbore's Avatar
Unhappy 2006 S Type
Hello Again, Well I yanked off belly shield & nasty nasty, looks like power steering pump leak so anybody know a good link for p/s pump, please advise !!
Old Jun 10, 2012 | 12:25 PM
Biggbore's Avatar
Thumbs up real jaguar mec found !!
Hello, I found a real honest Mec , he said my only problem with Jag was recirculating door hung open so was sucking in hot air while in stop n go traffic, so shine coming back a little @ a time !! but still have p/s leak but working kinks out one @ a time w/ your help THANKS
Old Jun 15, 2012 | 05:55 PM
Biggbore's Avatar
Default Remember when ??
Remember when your battery died & your get some friends to give you a push & you would be on your way ? Now days if you have a friend still around they aren't tech savvy either. Your grand kids can help with your phone but not your Jaguar. Well here I am pleading for help!!
radio code--where who?
locks--reprogram?
2006 S Type 3.0 38000 radiant red
Grand Pa
Old Jun 15, 2012 | 06:44 PM
You shouldn't need a radio code.
If you do the dealer can give it to you.
Old Jun 15, 2012 | 07:33 PM
Biggbore's Avatar
Default Remember when??
Radio does not play has code on screen ??
Old Jun 15, 2012 | 08:24 PM
xjrguy's Avatar
Your radio must not be properly set for the US. Shoot me a PM with the last six digits of your VIN# and I'll get you the code. When set for the US the code should be deactivated. I'll cover t hat when we have the code.
Cheers,
Old Jun 16, 2012 | 05:59 AM
Why did I have a feeling that you would say that?
stanjag
Dec 29, 2024 08:26 PM
1100me
Aug 27, 2020 11:37 PM
1100me
Aug 31, 2015 04:50 PM
Ian108
VENDOR 'For Sale' Classifieds
Aug 31, 2015 11:06 AM
1100me
Aug 28, 2015 09:48 PM
