2006 s type gearbox fault
Old Jun 19, 2016 | 03:49 AM
gr1's Avatar
gr1
Default 2006 s type gearbox fault
I have a 2006 s type diesel v6 91000mls a few week back I got abs/dsc fault I had this checked out need wheel sensor also showed gearbox fault. advised replace battery faults cleared but still have asb/dsc fault.had to go on holl when I came back my mechanic on holl. one month on gearbox fault back. when I put in drive or reverse the gearbox clunks/bangs also suspect in restricted performance due to wont go over 50mph on motorway at 3000rpm still on 3rd or 4th gear im not sure but wont change up. booked in at a gearbox specialist Monday as jaguar over the phone said sounds like gearbox internal fault they don't repair only replace 4000pound any advise welcome worried at potential cost
Old Jun 19, 2016 | 08:09 AM
gr1's Avatar
gr1
does anyone know the cost of a recondition s type v6 diesel turbo sport gearbox. thanks. or know the cause of banging/clunks when put into drive or revers. also have abs/dsc/gearbox fault
Old Jun 19, 2016 | 09:15 AM
Mikey's Avatar
Have you changed the transmission fluid or verified the level?
Get the ABS/DSC fault fixed to confirm it's not as bad battery or related electrical issue.
Old Jun 20, 2016 | 05:13 AM
gr1's Avatar
gr1
Default s type gearbox fault
hi thanks booked in today fit new wheel sensor hope it works
Old Jun 20, 2016 | 05:18 AM
gr1's Avatar
gr1
being told wheel sensor being fitted in a nutshell is wheel sensor is faulty the gearbox dosnt know what the wheel is doing I,e if your cornering a autobox wont change gear according to the mechanic makes sense. so with a wheel sensor not working the gearbox no idea what the wheel speed is so will shut down or limp mode. ill update later when sensor has been fit. if its the gearbox looking at 1800pound rebuild
Old Jun 20, 2016 | 06:03 AM
JagV8's Avatar
An chance you could put in enough effort to make your posts readable?
Old Jun 21, 2016 | 03:53 AM
gr1's Avatar
gr1
yes new wheel sensor fit problem solved. hope you can read this I was only offering advise not writing a novel sorry
Gingerorange
Jun 30, 2016 02:18 AM
Jaguar Forums Editor
E type ( XK-E )
Jun 26, 2016 10:00 PM
antonio ruelas
Jun 23, 2016 01:17 AM
Spikepaga
Jun 21, 2016 09:46 PM
Black1
Jun 17, 2016 09:05 AM
