2006 s type sport 3.0 air bag light
Old Oct 4, 2010 | 07:17 PM
Sixx Dogg's Avatar
Default 2006 s type sport 3.0 air bag light
Good evening everyone. Sat evening my air bag light blinked about 4-5 times...then stayed on....then it was fine all day Sunday...then today after I drove the car for 3 hours....it did the same thing...
I do have the easycare total care warranty thank god...but I was wondering if there is an easy fix for this so I do not have to pay the $200 deduct!
Thanx
Old Oct 4, 2010 | 11:14 PM
xjrguy's Avatar
Default Re: 2006 s type sport 3.0 air bag light
Your airbag light is telling you when it has discovered an intermittant fault in the system. If it has found a fault the light comes on, and on the next start the light comes on for a bulb test, then flashes a 2 digit code. For instance a driver airbag fault would be 1 flash, a short break, then 9 more flashes. That would be code 19. The code is flashed three times, then the light stays on. There are many circuits that could be the culprit, the most likely fault is the driver side. Usually the column cancellation module behind the steering wheel. [sometimes called a spiral cassette]
The airbag system is not something that I'd recommend for a home repair. Airbags are explosives, and therefore dangerous.
I'd recommend using your Easy Care and coughing up the deductible. Guesswork based on flash codes alone could end up quite expensive.
Good luck!
Old Oct 5, 2010 | 05:25 AM
carfix's Avatar
Worth a quick check of the air bag connections under your drivers seat. It will be the yellow wire and connector. It is not unknown for them to work loose over the years particularly if you have the automatic seat positioning.
Old Oct 5, 2010 | 08:30 AM
Sixx Dogg's Avatar
Thank you so much for the replies....I will check under the seat as soon as it stops raining outside.....and if thats not it Ill take her in...
Have a great day today
1100me
Aug 27, 2020 11:37 PM
h4wk
Nov 27, 2015 05:10 PM
peterg19
Aug 30, 2015 08:48 AM
1100me
Aug 28, 2015 09:48 PM
Chris New
Aug 27, 2015 03:14 PM
