2006 type R coolant nightmares!
Old Sep 27, 2016 | 12:44 AM
JB73's Avatar
Yes it's a supercharged R series. I think I will first try the double or triple stacked standard round o-ring. It's easy enough to get to & if it doesn't seal correctly, then I will look into other options. I just cant see buying a brand new hose at 75+ when it's such a simple cheap part to replace. Just another way for Jag to make a buck.... my new expansion reservoir should be in tomorrow. That alone with the o-ring fix should have me back on the road. After that I'll tackle the emissions low threshold check engine light icon_doh
I'll keep you guys posted.
Old Sep 27, 2016 | 01:37 AM
Datsports's Avatar
Originally Posted by NBCat
The vehicle in question is a SC model, which has a different hose arrangement.
the photo i supplied with the hose clamp set up is also super charged .it is from my 03 str .
Old Sep 27, 2016 | 01:41 AM
JB73's Avatar
Mine is a 2006 and evidently uses a different setup than 03.
Old Sep 27, 2016 | 01:43 AM
Datsports's Avatar
im guessing yours is a later model ? . and this may be one of the many changes they made . but i dare say this time not for the better .
(jaguar) what exactly was wrong with the old hose clip set up to warrant a whole new thermostat manifold casting and a different non serviceable hose connection ? you have to ask your self.
Old Sep 27, 2016 | 01:45 AM
Datsports's Avatar
sorry your post wasn't there when i asked that question . figured as much.
Old Sep 27, 2016 | 02:17 AM
JB73's Avatar
Your right, what was wrong with the original design?
What really gets me is that Jag only sells it as a complete hose assembly when they could easily offer the special o-ring!
This whole hose design with the o-ring and metal retainer clip is just silly anyways. What ever happened to the old tried and true hose with metal band hose clamp! LOL
Old Sep 27, 2016 | 02:29 AM
Datsports's Avatar
couldn't agree more , I've been there too,
i had to buy the whole expansion tank pipe set back when i purchased
my car . as it had an unreal assortment of entangled cable ties holding it on the tank outlet , instead of the steel clip . so it was $120 for a clip and a new o-ring to fix it . i later fitted the pipes to get my moneys worth .
Old Sep 27, 2016 | 10:19 AM
  #28
clubairth1's Avatar
Community Influencer
Sorry for the wrong info! My 2005 STR is different. This is one of the small changes that were made on the later STR's.
Why I don't know either. Same style of O-ring that I was talking about but a different size.
Old Sep 28, 2016 | 08:58 AM
JB73's Avatar
OK I found an o-ring simular in size to factory one.....installed it!
Next I replaced my damaged expansion reservoir!
Now my question is what's the BEST WAY to blled the system? When I removed the hose from the expansion tank I lost a lot of antifreeze.....
I topted off the new reservoir after it was I stalled. I donta want to damage anything knowing there's ano air pocket in the system due to all the fluid lost.
I know this supercharged R series has a unique reservoir with a large plastic screw ( blled screw I'm guessing).
Old Sep 29, 2016 | 08:45 AM
  #30
clubairth1's Avatar
As weak as that plastic screw is I never touch it!!
I have found the STR to self bleed very well. All I do is fill and keep checking the level for a few days. Usually about 2-3 small top ups and I am done.
If you read the manual there is also a inter-cooler bleed port on top of the manifold. Has a large hex plug in it. I never remove that one either.
Old Sep 29, 2016 | 09:55 PM
  #31
BlackKat's Avatar
An easy way to bleed without be to pace the front on ramps..this way the bleed screw on the expansion tank is the highest point on the system. Full with coolant with the key on but engine off. This way you have the intercooler pump will run helping to bleed out the intercoolers.continue until full, cap on and start the engine then slowly the bleed screw to remove left over air as the system warms. Once the bubbles stop you're good to go.
Old Sep 30, 2016 | 01:42 PM
  #32
JB73's Avatar
Thanks guys for all the help. I bled the system and was piece of cake.
No leaks anywhere that I can tell. No slight odors of coolant like I had before. Think it's all good to go now.
Next I'm looking into my o2 sensor fault codes. Will research and post a new thread on this issue. Thanks again everyone!
Old Sep 11, 2020 | 03:56 PM
  #33
JimSTR's Avatar
Sorry for the thread resurrection...
JB73... I have the same issue trying to seal that hose with a suitable o-ring... do you happen to remember what size you used?! Internal diameter, outer diameter, thickness? I'm partly guessing with the old one as it's so out of shape
Old Sep 11, 2020 | 07:06 PM
  #34
JB73's Avatar
I'm sorry I cant help with that info anymore......I sold that car several yrs ago because it became such a headache!!!! I did replace the seal and had to order it from the Jag dealer but dont remember the part #.
That car gave me such bad fits I thought I was going to run it off a cliff, luckily we dont have cliffs in Florida Lol.
Good luck on your parts search and repair.....the day I got rid of it was a Blessing. Hope you have better luck.
Lothar52
Oct 18, 2017 04:32 AM
ttuck666
Sep 21, 2016 01:07 AM
drmike
Sep 15, 2016 12:46 PM
randyb
Sep 1, 2016 02:08 PM
Rique
Aug 27, 2016 09:04 PM
