3.0L upper radiator hose
Old Jun 6, 2013 | 02:58 PM
TonyX's Avatar
Default 3.0L upper radiator hose
Is there a way to source the upper radiator hose without buying the complete assembly including the thermostat and the casing? I don't even need the turret part either, just the hose from the turrent assembly to top of radiator with a branch to throttle body.
This for 2005MY.
Old Jun 7, 2013 | 08:17 AM
JagV8's Avatar
I'm not aware of one but someone must make custom hoses or make something yourself I suppose.
Old Jun 7, 2013 | 11:36 AM
TonyX's Avatar
If I had a way to tee off of 2 inch hose to 3/8 inch hose I would attempt to make it myself. Do you know a way?
Old Jun 7, 2013 | 11:41 AM
A plumbers reducing tee?
Attached Thumbnails 3.0L upper radiator hose-900008309_0_9999_med_v1_m56577569830689401.jpg
Old Jun 7, 2013 | 11:57 AM
TonyX's Avatar
Ok, that's closer. But how would you put a rib there for leak control and for hose clamp to work?
Old Jun 7, 2013 | 01:08 PM
That was just to give you the idea, you would need to put a short length of pipe into each leg for the pipe to go on, I don't think you need a rib if you use a good clip.
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
Seth
Nov 1, 2015 12:17 PM
vwbusbits
Oct 13, 2015 03:43 AM
Camnelson324
Sep 27, 2015 08:48 AM
thedugger1
Sep 26, 2015 10:27 PM
