Abs fault and cruise not available
Old Nov 6, 2013 | 06:03 PM
alzy's Avatar
Default Abs fault and cruise not available
Hi
I have a 2005 S type 3.0 Jag. It was parked for a few weeks as i was on vacation and when i came back and started it got an abs fault and cruise not available warning. Funny thing is if i drive it for a while and switch off and restart the warning ges away. Any idea what is happening to my beloved baby.
Any advise is welcome
Regards
Alzy
Old Nov 6, 2013 | 06:24 PM
joycesjag's Avatar
How old is the battery Alzy?
Old Nov 7, 2013 | 01:14 AM
alzy's Avatar
Joycejag, its about 3 - 4 years old, could that be the problem, i really dont want to go to the dealer as i can see $$$$ flying away.
cheers
Old Nov 7, 2013 | 02:05 AM
JagV8's Avatar
+1 on battery
It might (but only might) recover enough if charged for 12+ hours.
Meantime make sure your key unlocks the trunk (boot) - keyhole below U of JAGUAR.
Old Nov 7, 2013 | 02:59 PM
jagreo's Avatar
Mine have the same issue but it was while running.
I just check the tire pressure and was fixed.
But also could be a bad connection or dirt in sensor of the tires.
The computer sense that tires are not spining equaly and gives that sing
Old Nov 8, 2013 | 05:31 AM
alzy's Avatar
Thnx jagreo. Will check the tire preasure. Any idea how to check the tire sensors.
Old Nov 11, 2013 | 03:44 PM
albert's Avatar
I have S type 2.5 2001 and experienced same fault over past two or three years, but was unable to find cause. BUT a few days ago, the ABS fault light on permanently.
May now be able to solve.
Old Nov 11, 2013 | 05:37 PM
police666's Avatar
I think he means abs wheel sensors or reluctor ring
Old Nov 11, 2013 | 11:31 PM
BanHugs's Avatar
Angry Traction Control Fault & ABS fault !!!! + more
Hey guys
This is my first post .... hope it works !! I have the same fault with my 1999 S-Type, 177K on the clock ... I love this car but to be honist is now costing me money each week with different faults. I have only had it 4 months & warranty just run out. Anyway, not the handbrake light has come on too.
I have taken all four wheels off & must admit there was water in the front two sensor housings, blew it out with compressed air, the back two are open to air although i did clean the teeth on the gear, still faulting, not got home today after going out for a few hrs & the blumin boot wont open without using the key, not by remote or by the switch in the cabin. GRRRrrrrrr...... me finks water has got into the electrics somewhere, oh & have checked the fuse, tis ok.
Old Nov 12, 2013 | 03:43 AM
alzy's Avatar
Hi
went to get my battery checked and was told the the voltage is about 12.6, which is lower than normal and i should get the distilled water in the battery changed. will try to get it done today and report back if that works. fingers crossed...
regards
alzy
Old Nov 13, 2013 | 12:41 AM
BanHugs's Avatar
Hey alzy
Dont think its your battery at fault, although probably not the full quid, my car has basically the same problem but I have a new battery ( 2months old ), im swinging towards a faulty sensor , gut dont know how to test it without the electronic reader, I do have an OBD11 scanner but it only does engine not chassis or sensor faults.
Regards
BanHugs
Old Nov 13, 2013 | 02:42 AM
JagV8's Avatar
12.6V sounds fine, ideally if it had been let stand for a couple of hours.
Old Nov 14, 2013 | 04:45 PM
jagreo's Avatar
Yep, Thats what I meant
bdboyle
Sep 16, 2019 05:58 PM
magmedia
Aug 15, 2019 08:54 PM
Dave1109971
Sep 30, 2015 11:04 PM
leep123
Sep 30, 2015 03:41 PM
Collector1
Sep 28, 2015 03:45 AM
