abs light and sudden loss of power
My abs light is staying on and my car (2004 S type with 4.2 V8) will all of sudden loose power and I feel a vibration, like brakes are kicking in and out. I try and give gas with a long delay. The car eventually goes back to normal. This happens too when I try and leave in the mornings in the drive way. Any help will be appreciated. Thanks
Yep, that will do it. Sounds like you need to replace a vacuum line or 2. I would start with the brake booster vacuum line, although there are other vacuum lines that could cause the faults.
If you google diy diagnostic smoker then you can check the vacuum pipes yourself easily at home.
buy yourself an elm 327 to read the engine codes they are really cheap.
