AC blowing only hot air
Old Jan 15, 2015 | 06:27 AM
albertonis's Avatar
Default AC blowing only hot air
Hello, I have big problem - AC blowing only very hot air. When I switch air on screen, blowing slightly cooler air, but itsn't normal cold air. I changed heater valves and climate control module. And nothing... Any ideas?
Old Jan 15, 2015 | 06:30 AM
albertonis's Avatar
I have Jaguar S-type, 3,0 l., 2001
Old Jan 15, 2015 | 06:41 AM
JagV8's Avatar
Carry out the tests to see what's wrong - see - JaguarClimateControl.com
Old Jan 15, 2015 | 08:35 AM
albertonis's Avatar
I know that website, but I changed heater valves and clima module and result is the same - only hot air
Old Jan 15, 2015 | 10:39 AM
Have you checked if the valve is functioning?
Old Jan 15, 2015 | 12:07 PM
JagV8's Avatar
The tests will get you the answer. Sounds like you rushed past them.
Old Jan 20, 2015 | 08:16 AM
P700Dee's Avatar
Damaged loom behind the front bumper, happened on mine. You need to remove the bumper , un wind the loom and repair the breaks.
Old Jan 20, 2015 | 09:46 AM
tbird6's Avatar
Before you tear into the loom follow the other advice above.
You must see what the DCCV is getting as far as voltage before you can go farther.
You are just shooting in the dark and changing parts most likely won't fix it.
Do the troubleshooting first. Then purchase parts.
Did you put a new or used climate control module in?
New DCCV's have been bad out of the box too. Need to check all this.
Please don't tell me you put a used DCCV in?
Remember we are all a very long way away and at best we are just guessing at your problem. Please help us to help you.
Old Jan 20, 2015 | 05:04 PM
As your car is an X200, check the #1 fuse in the engine bay fuse block.
That fuse supplies volts TO the centre wire of the DCCV. A faulty DCCV WILL blow that fuse. One of mine did that.
With NO volts in that wire the DCCV defaults to FULL OPEN, so HOT air all the time.
Old Jan 20, 2015 | 05:56 PM
JagV8's Avatar
Which the tests reveal.
02jagstype
23
Oct 23, 2022 07:03 PM
stype40
Sep 9, 2015 08:14 AM
OkieTim
Sep 8, 2015 04:48 PM
Corycarlo
Sep 5, 2015 11:41 AM
OkieTim
Sep 2, 2015 12:48 PM
