AC Compressor 101
Old Sep 2, 2011 | 07:25 PM
dthompson7's Avatar
Default AC Compressor 101
Just repalce cool fan and daul coolant flow value. Pump down Ac compressor and and new ac 134 fluids. The compressor kick on and off at idle and when driving. Is that normal? The ac blow cool air
Old Sep 2, 2011 | 07:36 PM
joycesjag's Avatar
sounds like its working(?!), I think.
Old Sep 3, 2011 | 01:05 AM
JagV8's Avatar
I think if it cycles often it's struggling. Er, but I don't know how often "often" is!
Reasoning: it's aiming at the temp you've set. It's a control system with feedback so will be constantly correcting, but will have a small amount of tolerance (hysteresis). If it cycles too often it will be because it can't hit the "set point" (your selected temp). Commonly due to not enough a/c gas (R134a), because then the low pressure cut-out keeps triggering. That's not the only possible cause (high pressure cut-out is another) but because the gas gradually escapes, it's the one you expect.
Old Sep 6, 2011 | 08:16 AM
dthompson7's Avatar
Thanks JAGV8, that make alot since to me. I filled the ac system to it spec.
04Xjrsteve
May 7, 2019 04:06 PM
dmatthewman
Sep 30, 2015 10:10 AM
dan102877
Sep 29, 2015 06:47 PM
tonyforman
Sep 10, 2015 07:23 PM
