Add front fog lights on S Type
Old Apr 17, 2014 | 06:13 AM
ONEsicJAG's Avatar
Lightbulb
My Next Move Would Be Trying To Swap Out The Headlight Switch Pack To One That Actually Has The Fog Light Option/Button.. Just A Thought. Good Luck!
Edit: After Re-Reading Your Last Post I Believe You've Already Tried This?..
Old Apr 17, 2014 | 01:44 PM
DukeOfStyria's Avatar
Re. "edit": yes, I got another fog lights' switch which has both switches - front and rear.
but tx
M
Old Jul 13, 2014 | 01:02 PM
Post Front fog lights on 2008 S Type 2.7D
hello folks,
since alle my (3) girls where out of the house and the weather not too bad neither - I could fit my fog lamps onto the car finally.
And yes - I have checked with my friendly dealer - the 2008 model really never came with fog lights (even that the wiring was behind the blinds as discovered earlier). Which meant in conclusion - there would be no factory holders available - neither new nor used ones! So I decided to convert the blinds into holders for the lamps...
To make a long story short (~ 10 hrs):
  • I made a stencil how to make the cut-outs on the blinds.
  • Then I fitted the fog lights.
  • Next I filled the space around it with some polystyrene.
  • Covered the polystyrene with fibre-glass and epoxy
  • Painted the whole thing with modelling paint (spray) and filled a few holes with silicone - to prevent spray water getting inside.
The worst had been the cut-outs since the blinds are made from quite sturdy plastic and to get the polystyrene into proper shapes.
Attached Thumbnails Add front fog lights on S Type-20140713_104515_s.jpg   Add front fog lights on S Type-20140713_104443_s.jpg
Old Jul 13, 2014 | 01:12 PM
Smile 2008 S Type with front fog lights
And now finally that's the result. In my opinion it looks pretty well. The critical ones may consider that I've never worked with fibre-glass/epoxy before.
Since the fog lamps have the same shape of the original ones (on the Mk II series) - I don't think the LEDs look worse than the original lamps had been.
"Quod erat demonstrandum"
A small note on the replacement lamps sold from Adamesh:
pros:
- they fit into the original place from the latter models
- they are "plug'n play" if your car had fog lights before
- for GBP 35,-- they are fairly cheap
cons :
- I had some "bad contact" issues when fitting them. Seems to work only in a certain position of the wires.
- I am still in doubt how the result will be when driving in bad weather conditions. But being said the original ones being useless - can't be worse neither
And here how it looks finally:
PS: no, I did not take the time to wash the car...
Old Jul 14, 2014 | 03:44 AM
baggienigel's Avatar
Can't be sure but from my less than good memory you won't get power to the fogs unless the sidelights at least are active/on. Hope this helps and good luck!
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
Goncalo Proenca
Sep 8, 2015 06:06 PM
gene1
Sep 3, 2015 08:04 PM
gene1
Aug 27, 2015 09:35 PM
