Air Bag Warning Lamp
Old Apr 15, 2009 | 05:57 PM
TxJag's Avatar
Default Air Bag Warning Lamp
I have a nagging problem with my 2004 S-Type. Periodically, the air bag warning lamp will illuminate on the instrument panel. This is most common in warm weather, and happens infrequently in cooler weather. It will begin flashing, then after a time will burn steadily. There is no clear pattern to when this crops up. The car may go weeks without any problems, then it will get into a "mood" and flash everytime I drive. As stated, more of a nucience than anything, but I'd like to correct the problem. It's been going on now for over a year.
If anyone has encountered this problem, or knows of a resolution, I'd be interested to hear.
Cheers,
JD
Old Apr 16, 2009 | 10:19 AM
dwhitall's Avatar
I had my airbag warning light come on once. Well actually it didn't go off (it comes on when engine is started). I restarted the car and it went off properly. I've also seen this on other cars as well, so I think there can be an occasion where the "check" doesn't read correctly.
Old Apr 16, 2009 | 04:03 PM
H20boy's Avatar
Hey JD, the airbag light is something that I have heard in other forums, may want to try a forum-wide search. If it flashes and then remains on, that's code for something.
Old Apr 17, 2009 | 11:04 AM
stdjrm17's Avatar
I have a 2004 and some of the time when my fiancée sits in the passenger side the airbag light will flicker on and off (the light on the dash above the glove box). When she moves around it will go off. She is not very big maybe 110 pounds so I wonder if it is something with the sensor. Is this like the problem you are having?
Old Apr 18, 2009 | 08:33 PM
TxJag's Avatar
No, unfortunately, your problem sounds different than mine. The light on my car is the one in the instrument panel cluster. It sometimes begins flashing after the car is driven for awhile (sometimes almost immediately, sometimes not for hours) and then burns stedily. I have watched the lamp you mentioned, and it seems to behave normally. Thanks for your response.
JD
Old Apr 18, 2009 | 08:36 PM
TxJag's Avatar
Thanks; I've done some other reading, and it appears that it will take a reader to sort out the codes. To your knowledge, is the dealership the only one who can read the codes and/or diagnose, or can an independent perform the service? If so, are there any competent ones here in the D/FW area? We moved here from San Antonio about a year ago, and am still largely unfamilar with the area.
Thanks!
JD
Old Apr 19, 2009 | 11:21 AM
12RM's Avatar
Most likely the "spiral cassette" or cancellation module.
Covered here - http://www.jaguarforum.co.uk/viewtop...0&hilit=spiral
and a number of other times.
Note - the number of flashes are a code for those that do not open the link.
Hope that helps.
Old Apr 20, 2009 | 04:03 PM
TxJag's Avatar
Hope that helps.
Thanks, 12RM, for the link; it hit the nail on the head! Coincidentally, the code that was addressed in that link (19) is the same one I'm experiencing. So, it appears to indeed be a spiral cassette, as you indicate.
Now, is this something that is easily replaced, or strictly a dealer-only repair? I prefer to do all the work I can myself, and would rather invest in manuals and tools rather than pay the dealership service department. If it is a component that rests underneath the steering wheel, then I suppose it should be fairly easy to replace.
Are there any Jaguar service technicians out there who can give me some advice whether to "DIY", or schedule an appointment?
Thanks,
JD
Old Apr 20, 2009 | 11:16 PM
H20boy's Avatar
JD, next time something comes up and you need an OBDII reader, let me know. My autoengenuity scanner (for the PC/Windows) has the enhanced codes and can read subsystems like ABS, airbags, seat modules etc.
Looks like you know what you need. There are lots of guys who can get you parts...jagtechohio, jag_genious, and ken@britishparts. If you go to the dealer (autobahn), ask for Lee; he is a really good guy and he'll take care of you the best he can.
Old Apr 21, 2009 | 07:40 AM
TxJag's Avatar
Thanks for the offer; I'll keep that in mind for future reference. I'll contact you off-line to get some details on parts sources.
Thanks,
JD
Old Jul 6, 2009 | 04:41 PM
billings's Avatar
Default Same Problem
I have the same problem. Did you confirm the issue and get it fixed?
Old Jul 8, 2009 | 08:20 PM
TxJag's Avatar
No, I'm still putting up with it. I was going to order the part from Motorcars LTD in Houston. I called to order the part and inquire about the installation method. They promised to call me back with the installation information. But after making three follow-up phone calls (to the same person), and getting nothing but the run-around, I gave up on them.
I want to find out how to do the swap before buying the part. I was hoping one of the Jaguar mechanic guru's on here would step up with some information, but so far, no info. I would't be afraid to just tear into it, but I don't want to inadvertantly set off the airbag thru ignorance.
If someone can give me the procedure basics, I'll go to my Jag dealer and order the part. At this point, I don't care if Motorcars is 1/2 price, they're not getting any of my money due to poor customer service.
Good luck with yours.
JD
Old Oct 26, 2009 | 04:25 AM
pantheon's Avatar
I have this same problem with passengers in my 2003 Jaguar S-Type 4.2 V8. The passenger airbag lights up, then turns off with some wiggling by the passenger. I'm assuming it's the sensor in the seat, but does anyone know where all the other sensors are? Are they all those little vent looking things, (the ones that are a little smaller than a dime and look like microphones) all around the car? Is there any way to test the sensors for the passenger side airbag?
Old Oct 26, 2009 | 10:06 AM
tbird6's Avatar
I think you will find the part is called a "Clock Spring" in the US. It's under the steering wheel and is not that difficult to change. Another symptom can be other steering wheel functions will act strange or stop working. Any weird radio or cruise control things going on?? Does the horn work OK when the steering wheel is turned??
Old Oct 26, 2009 | 10:22 AM
JagV8's Avatar
I think it's covered in the handbook, that the seat is weighing the passenger. The airbag will only be armed if the person is above a set weight, as otherwise it would not be safe. Sounds quite normal. I'm guessing that someone on the boundary of being heavy enough would cause it to stuggle to make its mind up
Old Oct 26, 2009 | 10:36 AM
JOsworth's Avatar
To add to JagV8's comment. The seat has sensors that not only look at weight, but also look for the distribution of that weight. My 7 year old @ 60lbs turns off the airbag (the warning lamp lights on the passenger side). Her mom @ 120lbs (Oh boy, she's gonna kick my *ss for posting that! ) only sets off the "airbag off" warning when she sits in the car with one leg tucked up underneath herself (don't ask me why girls sit like that..I don't know). In the manual as well it talks about having the weight properly dispersed. So, try different people in the seat and see if the lamp works properly.
Old Oct 26, 2009 | 11:35 AM
JagV8's Avatar
hey, 120 is a good weight!
unless she's very height-challenged LOL
Old Oct 26, 2009 | 01:37 PM
JOsworth's Avatar
Not to pull this thread too off topic... But she was around 110 before the baby, so now it's my fault!
Old Oct 26, 2009 | 02:10 PM
JagV8's Avatar
oh well, if we're going totally off-topic....
she was putting up a fight?
and it IS yours?
(runs ------> )
Old Oct 26, 2009 | 04:10 PM
JOsworth's Avatar
You know we're gonna get in trouble for being comedians.....
LOL, that's what I told her.... I thought it was a team effort, unexpected or not!
Yea, the baby is definitely mine... When it's after 5pm she's had enough and is a grumpy butt until you put her to bed! I've been tempted to pass her the remote, but hell, she's only 3 months old!
