air con condenser
Old Oct 17, 2014 | 10:44 AM
iveseyboy12's Avatar
Default air con condenser
Hi
Any advice on replacing the condenser on a 2001 3.0V6 s-type? Do i need to remove the bumper or can i get it out from underneath?
cheers all
Old Oct 17, 2014 | 11:06 AM
JagV8's Avatar
From above, I expect, but maybe JTIS says.
Old Oct 17, 2014 | 12:40 PM
If it's like the later ones it's bolted to the radiator, so as JagV8 says out from the top radiator first.
Do you have JTIS? if not you can download it from the forum, and don't forget the intro in the new member section.
Old Oct 18, 2014 | 06:55 PM
tony1963's Avatar
You can pull the condenser out from the bottom very easily. Remove the lower coverings, vacuum down the system, pull the lines off the condenser (including the stud that holds the lines to the condenser so that they don't get caught on anything), remove two bolts below bolting the condenser to the rad and it comes right out.
scooternva
29
Mar 25, 2025 12:45 PM
mel
Sep 20, 2015 04:56 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Na5h
Sep 11, 2015 07:26 AM
tonyforman
Sep 10, 2015 07:23 PM
