Another audio question!
Old Dec 1, 2013 | 10:16 PM
msljag's Avatar
Default Another audio question!
I replaced my standard audio radio recently with a JVC double DIN head unit, and it works well. The USB and BT are great. But... after listening for a bit, decided to try some different speakers up front, and put in Infinity Reference replacements in the front doors which improved the high frequencies a lot.
However, in comparison I found the OEM speakers on the S-Type are quite decent and are better at delivering bass, so decided to leave the OEMs in the rear doors (plus having to pull 2 more door panels to replace speakers convinced me to keep them ). It's a nice combination.
That said... I still want to add a subwoofer. To do so I need to run wiring from the head unit area to the boot, as I don't think my Jag has anything pre-wired for it. I'm sure a car audio installer could do this for me, but when I initially took my Jag into Car Toys, once they took a look at the the car the costs start adding up fast.
Has anyone added subwoofer wiring to a standard audio S-Type and if so what's the best way to go about it?
Old Dec 2, 2013 | 04:02 AM
manycars's Avatar
If you've replaced the HU with JVC one, then you will be wiring a sub from that, not the S Type wiring?
Old Dec 2, 2013 | 08:15 PM
msljag's Avatar
Right, I would need to run low level audio out (RCA) from the back of my new HU plus an on/off amp control signal to the trunk, then add an amp and sub in trunk (or maybe an all in one unit). I don't think there is any pre-wiring in my S Type - so I was wondering the best way to run some wires to the trunk on my own.
Old Dec 3, 2013 | 01:58 PM
manycars's Avatar
Under the carpet, along the edge?
Dz1rfj
Jul 17, 2018 10:29 AM
thechaosmachine
Sep 23, 2015 10:03 PM
Dz1rfj
Sep 16, 2015 03:44 PM
tberg
Sep 7, 2015 07:32 AM
