Another ZF Thread
Old Nov 19, 2018 | 12:52 AM
RobGardnerBlack's Avatar
Default Another ZF Thread
My 2005 STR transmission started to slip recently under load on 4-5 and 5-6 along with 3-4 harsh upshift. Checking for codes I found incorrect gear ratio codes which is an indication of something mechanical.
I dropped the transmission pan and valve body to get a limited keek in at the clutches; from what I could see there were burnt clutches. Out with the transmission and onto the bench for strip-down. If like me you don’t have a lift it's not much fun pulling it out.
Found E-Clutch was shot, frictions worn down to the metal and resulting damage on the steels so installed a new set of steels & frictions throughout, new sleeves and overhauled all rubber. Also freshened the valve body with a Sonnax kit and picked up a reman'd TC from Torco in SoCal.
All back together and on the road running very nicely, the only thing I did not do was re-set the TCM adaptations; issue with an expired license on my software stopped me. I have just under 1k miles now, but I think a dealer trip for a re-flash/update is in order to get full advantage.
Cost was just over $1k in parts, 36 cups of tea, 2 fish dinners and 6 bottles of Buckie.
Old Nov 19, 2018 | 06:21 AM
Jon89's Avatar
Well done....
What ATF did you opt to go with after the rebuild?
Old Nov 19, 2018 | 09:19 PM
I went with the Castrol Multi vehicle this time; was running Redline for 70k miles.
Appears to be working well. My only feedback on this is to ensure you have a genuine pan when you replace.
Old Nov 20, 2018 | 04:28 AM
wydopnthrtl's Avatar
This is my kind of post. Informative and by a real DIY'er. Thanks!
Old Nov 22, 2018 | 03:12 PM
Busa's Avatar
Nice work!
Old Nov 22, 2018 | 05:26 PM
abonano's Avatar
Awesome. Read your initial post and was going to say E Clutch but you already knew it.
Oct 24, 2019 07:07 AM
JTsmks
May 24, 2016 10:45 PM
bigcat
Nov 17, 2010 01:51 AM
aughsum
May 29, 2007 09:44 AM
