Any history of transmission module (TCM) going bad? 03 S-type V6
Old Feb 9, 2015 | 07:32 AM
car5car's Avatar
Default Any history of transmission module (TCM) going bad? 03 S-type V6
I have code "no communication with TCM"
Any ideas?
Thanks.
Old Feb 9, 2015 | 07:45 AM
ccfulton's Avatar
Electronic failures in the TCM are not something you hear about very often. Most problems are mechanical wear in the hydraulic system.
Do you have any other communication faults? My first suspicion would be an issue with the CANBus network, which should affect a number of components.
Old Feb 9, 2015 | 11:38 AM
JagV8's Avatar
How often has it happened?
If it keeps happening you're most likely looking for a bad connector or chafed wire, but if it's just once then ignore it.
But... always check the battery!!!!!!! A failing battery throws weird codes and you'll swear it's good because it starts the car - worst "proof" imaginable.
Old Feb 9, 2015 | 01:19 PM
abonano's Avatar
Originally Posted by car5car
I have code "no communication with TCM" Any ideas? Thanks.
did you change the electrical sealing sleeve recently?
Old Feb 9, 2015 | 07:48 PM
car5car's Avatar
What is it?
I just bought the car, battery was partially discharged, I charged it and most codes disappeared. There were probably 20-30 codes from different systems, now about 5-7 left.
Transmission is in limp mode because there is no communication from TCM.
Thanks for all responses. There is a chance just to have electrical problem, not mechanical transmission one. I know it is Ford V6 engine (Ford Contour, Mercury Cougar), hopefully it is Ford transmission.
Old Feb 9, 2015 | 09:25 PM
abonano's Avatar
On the back of the transmission you will see an electrical connector - make sure it is tight, snug and dry and not leaking transmission fluid onto the connector...
Old Feb 10, 2015 | 01:46 AM
JagV8's Avatar
It's very unlikely to be a bad TCM so you're looking everywhere else first. But a false code from a below par battery is #1 suspect.
aholbro1
Dec 29, 2024 06:46 PM
Wolfy
May 28, 2024 08:06 AM
XJsc-guy
Sep 25, 2015 11:09 AM
jaguarbill
Sep 5, 2015 11:43 AM
02jagstype
Sep 4, 2015 08:20 PM
