Anybody bypass Active Shock Damping Function ?
Old Jun 25, 2019 | 01:28 PM
dauraf's Avatar
Default Anybody bypass Active Shock Damping Function ?
I want to replace my stock CATS struts (front and rear), the active ones are really expensive and I think I can live without them. After some research found this device that promise get rid of electronic struts without the annoying messages and errors. Does anybody have any experience with such devices (I've been checking deep in the forum without any luck) or maybe just a 25watt 3.9-ohm resistor (as I found somewhere else) is enough?
manufacturer link to the product: APDTY APDTY 27389 ELECTRONIC SUSPENSION BYPASS 27389 | Auto Parts Direct To You
a reseller with a little more information: https://www.aghanimarket.com/index.p...ducts_id=89177
some extra information: http://www.monroe.com/downloads/inst...M01154RevA.pdf
... or just unplug the control module ?
Old Jun 26, 2019 | 04:29 AM
M-e-l-l-o-w's Avatar
The first thing to do is to make sure your original struts are no good.
They are known to 'weep' a tiny amount of oil that over several years can make them look like they are leaking.
Clean this all up, including under the plastic cover and then run them for a week or so and see if it comes back. The chances are it will not.
Then just check them from time to time and before any vehicle test.
Mellow
M. Stojanovic
May 27, 2018 07:06 AM
Simran Singh Randhawa
Dec 6, 2016 10:12 AM
auburn2
May 7, 2014 08:04 AM
Rezzz
Feb 10, 2014 10:26 AM
H20boy
General Tech Help
Oct 31, 2010 08:27 PM
