Autologic on XJR (X306) and S-Type - what settings and adjustments
Old Sep 25, 2012 | 11:45 AM
Christian 96 XJR's Avatar
Default Autologic on XJR (X306) and S-Type - what settings and adjustments
I am going to have the door auto-lock function disabled on two of our Jaguars - a 1996 XJR and a 2001 S-Type.
Since the major cost is hooking the cars up to the system, I am thinking about other settings/configurations/adjustments that I should ask for at the same time.
Here's what I have for the 1996 XJR
- disable door auto-locking
- Reset Adaptive Terms [Zero out fueling adaptions]
- reorient Oxygen sensors (should be correct, not like this setting drifts :-), but the fuel economy isn't the greatest, and I don't feel like experimenting by switching oxygen sensor connections)
- Throttle Adaption Reset/calibrate idle speed (no issue at this time - idle is stable at 700? RPM - maybe best not to touch?)
- other settings???
Here's what I have for the 2001 S-Type
- code additional remotes for lock/unlock
- other settings???
Or if someone has a list of the configurable options/parameters for these cars, that would be great.
Also, I've been following the cloned dealer scan tool thread. However, I am unclear as to whether anybody managed to get a Mongoose cable + SDD/IDS v125 through v130 to actual talk to and configure X300s and X200s.
And the authentication for SDD - does it require an Internet connection (with forced update to V131 Patch 4 or later) or is it a built-in username/password authentication mechanism?
I'd really like to be able to do the module setup/encoding and powertrain adjustments myself rather than going to a shop. I don't need PCM flash capabilities (XJR does not support flash and has latest EPROMs, S-Type has latest - and probably 'last ever' - version of the PCM software)
Thanks,
Christian
Old Oct 18, 2012 | 10:27 AM
H20boy's Avatar
Christian, did you do your 'laundry list' of vehicle changes?
XJsc-guy
Nov 23, 2015 01:56 PM
XJsc-guy
Sep 25, 2015 11:09 AM
philwarner
Sep 6, 2015 11:10 PM
34by151
Sep 6, 2015 05:14 PM
colorancher
Sep 3, 2015 02:29 PM
