Automatic windows
Old Dec 29, 2008 | 01:43 PM
Toller's Avatar
Default Automatic windows
2005 S-Type.
I have automatic windows. The drivers side stopped doing the automatic down, required the button to be depressed for the full time.
The service manager said I could re-program the windows. He had me start with the windows full up, press both buttons and hold them until the windows were down plus 5 seconds. Then I had to do the same thing to put them up. I was to repeat the sequence 3 times.
It worked. Two weeks later, the program failed and I had to do it again. Now, after a few days, it's failed again.
Is there some step like baying at the full moon or some such that I should also be doing to make this stick?
Eric
Old Dec 29, 2008 | 02:49 PM
Brutal's Avatar
Default RE: Automatic windows
NO YOU HAVE TO BAY AT THE MOON, BUT IT HAS TO BE A HARVEST MOON.
ACTUALLY EITHER THE MODULE IS BAD OR YOURE LOOSING POWER INTERMITTENTLY TO THE MODULE THAT RETAINS MEMORY, MUCH LIKE DISCONNECTING THE BATTERY
Old Dec 29, 2008 | 10:20 PM
Toller's Avatar
Is there anything I can check to say r/o a loose connection? Is the module in the driver's door switch?
Thanks.
Eric
sedonajag
Oct 8, 2015 07:38 PM
Markus
Sep 28, 2015 01:55 PM
jjmiah217
Sep 28, 2015 09:09 AM
sedonajag
E type ( XK-E )
Sep 27, 2015 05:19 PM
UKnFor-dluv-expat
Sep 26, 2015 08:40 PM
