Bank 2 Side
Old Aug 2, 2012 | 09:56 PM
weldboy's Avatar
Default Bank 2 Side
I have a 02 S type 3.0, if your sitting inside the car which is the Bank 2 Side ?? I think it would be the left side or drivers side???? Thanks
Old Aug 3, 2012 | 01:22 AM
JagV8's Avatar
Left side, yes. (Here that's the passenger, there it'll be the driver.)
Got a code/problem?
Old Aug 3, 2012 | 07:10 AM
abonano's Avatar
Driver's side - (US)
Old Aug 3, 2012 | 09:43 AM
weldboy's Avatar
Yes, I got a P0430 code, thought I'd change both of the 02 sensors first, it just passed a smog test a few weeks ago, so I doubt that's it the cat coverter. But you never know. Thanks
Old Aug 3, 2012 | 03:09 PM
abonano's Avatar
Code P0430 = catalyst efficiency below threshold bank 2 (cat converter) - Have you checked your coils and injectors for proper operation on bank 2 - worth a check weldboy. You could try resetting the code but if it returns more than likely an issue, which will need to be rectified rather quickly.
Old Aug 3, 2012 | 03:19 PM
JagV8's Avatar
Check fuel trims. If OK, next check O2 sensor operation (look at graphs / try propane). If trims not OK, look for air leak etc as appropriate. Changing parts quickly gets costly.
Old Aug 3, 2012 | 04:34 PM
weldboy's Avatar
I have replaced all of the coils a few weeks ago, this is the second time it has set off. Will check the fuel trims next. Thanks
danke
Mar 3, 2016 10:57 AM
RoyLittle0
Sep 17, 2015 01:05 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
KarimPA
Sep 12, 2015 08:15 AM
jaguarbill
Sep 5, 2015 11:43 AM
