battery drain
Old Jun 20, 2016 | 01:37 AM
scotsgeeza's Avatar
Default battery drain
hi all
ive got a battery drain being caused by air con i have removed fuse for air con and all working fine any ideas on cause
tia
george
Old Jun 20, 2016 | 04:06 AM
Might pay to add your car YEAR, and engine size, etc, to your sig. The X200 is different to the X202, and so on.
Maybe the compressor has seized, thus causing the relay to "stick" on, but that is a guess.
Old Jun 20, 2016 | 08:41 AM
scotsgeeza's Avatar
hi there many thanks its a 2004 2.5 v6 s type
regards
george
Old Jun 20, 2016 | 10:11 PM
Datsports's Avatar
i would have said crook relay , it may have failed on its own at this age . well worth checking to see if the pump turns or not as stated above , as well as checking the clutch activates ,
have you checked to see how many amp's its drawing with a multi meter ? also does the clutch on the compressor click on when you fit the fuse ?
Old Jun 20, 2016 | 11:59 PM
scotsgeeza's Avatar
many thanks
g
Old Jun 22, 2016 | 07:50 AM
aholbro1's Avatar
There's a thread...possibly a sticky; some member here wrote a step-by-step guide to tracking down battery drain issues. Might be worth a look for you.
Old Jun 22, 2016 | 08:01 AM
JagV8's Avatar
There's also a jag how to which will be in the stickies/files area/etc
Search will find threads, just then have to read and read...
silversurfer1221
27
Sep 27, 2022 02:06 PM
klintous
Apr 15, 2022 10:44 PM
silversurfer1221
May 10, 2016 08:00 PM
NathanDD6
May 8, 2016 02:11 PM
Ronco1
General Tech Help
Apr 21, 2016 12:37 PM
