Battery drain - dead after 3 days
Old 06-02-2011, 03:28 PM
usmantariq's Avatar
Originally Posted by jagv8
What makes you think that will make any difference?
Bcoz i was suffering the same issue in 2003 s type.. Battery drain in Jst one day.. Now after doing these 2 things .. No more drain for 8 to 9 days ...
Old 06-02-2011, 06:07 PM
JagV8's Avatar
Received 4,489 Likes on 3,906 Posts
Something very wrong if that happens. Is it a car with the factory sat nav?
First time I ever heard such a thing on any S-Type forum.
Old 06-02-2011, 06:29 PM
usmantariq's Avatar
nah its without Sat Nav.. really i was a problem with me.. but after pushing off both switches its working fine.. Main Fan Switch And Main Audio Switch..
Old 06-02-2011, 09:52 PM
JagV8's Avatar
Does your car have a VIN before M45255?
Old 06-03-2011, 04:16 AM
JOsworth's Avatar
Hmm... Those actions may have stopped the issue but they are not the cause.. Need to investigate why those items are causing a drain if left on after you turn the car off. It should not matter.. I have never had any car where the battery would drain if you left the climate control or radio on..JagV8 is pretty good with electrical systems if you are willing to test stuff. He and other users may be able to get to the root cause if you want to figure it out.
usmantariq (06-03-2011)
Old 06-03-2011, 10:14 AM
Kapitan1975's Avatar
I have similar problem with my STR, the battery just drained in few days... got some tips from brutal to check the ignition switch (just the electrical part). so i called Nalley and order the parts. (which was 3 months ago) and still sitting on my desk.
Found simpler (still temporary solution) i installed a trinkler charger to the battery and doing fine every since.
Old 06-03-2011, 04:47 PM
usmantariq's Avatar
no its after m45255 ...its M919.....
  #28
Old 06-03-2011, 04:52 PM
usmantariq's Avatar
yeah u r v right...but what should i do i don't know...i think mine v6 its 3.0L sports...i'll b v thanks full if some one could help me for this issue..i don't have any workshop here in Pakistan who could deal with Jaguar..i can just buy the parts from UK and can fit myself...thats all...
Old 06-04-2011, 07:19 AM
JOsworth's Avatar
I would start with the ignition switch. Just the electrical switch, not the lock part. Do a search here on "ignition switch". Look for posts by a user "Brutal". He is a Jaguar Dealer Service Tech here in the US. He is the one that has pointed users to this issue. It is pretty common. What happens in short is that the switch doesn't fully power off, leaving some modules on. With yours, it may be enough to shut off power to the radio and climate control first... The remaining modules that stay on may not be enough of a drain to kill your battery. Just remember, the more cycles of charge and discharge a battery goes through, the shorter it's life.. I know, because I have a battery tender on my collector car, it's battery has to be replaced every couple of years. I do it because with out it, I was killing a battery every year.
usmantariq (06-04-2011)
  #30
Old 06-04-2011, 07:59 AM
JagV8's Avatar
+1 on that
  #31
Old 06-04-2011, 08:41 AM
usmantariq's Avatar
Hmmmm . Thanks a lot..I'll just do it now..
  #32
Old 06-04-2011, 06:01 PM
usmantariq's Avatar
i just checked all posts regarding battery Drain.. and the conclusion is
90% chances are faulty ignition switch.
10% chances are electric modules.
i think i should change the switch first and if don't works ill go for modules.
now i'm waiting for full access so i could see the diagram attachments from other users..
Nervosa (01-24-2012)
  #33
Old 06-05-2011, 03:38 AM
Leedsman's Avatar
As Josworth said, if you keep a lead-acid battery near the top of its capacity, i.e. if you don't discharge it much and therefore don't have to charge it much either, it will last very much longer. But if you have an application like those battery wheelchair things that old people use, there is another kind of lead-acid called the "deep-discharge" type that's specially built for being discharged down to near empty.
Leedsman.
  #34
Old 06-05-2011, 09:57 AM
JagV8's Avatar
Sounds like marine batteries (not sure that's the proper name LOL).
  #35
Old 07-17-2012, 02:56 AM
RogerPrince's Avatar
That was really helpful dijmand. I will get my local garage man to check my Jaguar S Type
  #36
Old 08-22-2013, 02:21 AM
gr1's Avatar
gr1
gr1 is offline
iv got the same fault on my 2004 s type diesel drawing 0.9amp but the battey is fine for about 2 week then without warning flat my alternater and battery check show they are ok im still searching for a cure
  #37
Old 08-22-2013, 03:45 AM
JagV8's Avatar
Lots of threads, with usual suspects and fixes. Gonna take quite a bit of reading but it's all on here.
  #38
Old 08-22-2013, 03:59 AM
jimbov8's Avatar
Hi,
The chart attached will tell you what you should be getting when the car is "asleep".
The usual suspects,
When you remove the key from the ignition, has the little flap closed?.
Confirm all courtesy lights go off.
If you have the auto function for lights, switch them off.
Switch off the steering column adjustment.
Switch off the auto function on wipers if fitted.
Confirm when locked, no warning on message centre.
These few things should help you track it down then all you have to do is rectify it.
Hope this helps,
  #39
Old 09-30-2013, 02:42 PM
JuliaDent's Avatar
Hey, Guys,
My 94 XJS battery has been failing after sitting for only a week. This is unusual as she oftens sits longer than that. I went to charge it and found liquid in the tray beneath the battery. Does not smell like batter acid. Could this be water? Charge was slowwww and I interupted it before it was finished when I noticed the liquid. Any ideas? Also, if the battery (a TrueFit from my Jag mechanic) is bad, can you recommend an aftermarket brand. I do use a trickle charger for long naps.
  #40
Old 09-30-2013, 03:42 PM
tbird6's Avatar
Wrong place. We are for S Types which are completely different from the XJS.
You will do a LOT better posting your question on a XJS forum.
aholbro1
08-05-2021 05:02 AM
99xk8guy
09-21-2019 07:34 PM
Scarecrow
03-28-2016 03:17 AM
al_roethlisberger
09-11-2015 10:04 PM
obwoodie
09-03-2015 07:45 PM
Quick Reply: Battery drain - dead after 3 days
