Battery drain- s-type
Old Jan 28, 2013 | 04:47 PM
britishracinggreen's Avatar
Unhappy Battery drain- s-type
Hi everyone,
My s-type battery went completely flat. I put this down originally to the apparently common leaky boot problem. All is now dry!
My battery was charged but once again went flat.
The battery seems fine, 12.7V and is 6 months old. The alternator is giving out 13.8V, I assume also fine.
Does anyone know the resistance I should get measuring acroos the battery leads, with the battery removed and the ignition off????
p.s. changed the grill to SS mesh and will be loading pics soon, love it....
Old Jan 28, 2013 | 05:26 PM
JagV8's Avatar
No point in measuring the resistance. It will change with time by a lot but also your meter will output a low voltage so would read something weird.
You can read current with care - it may be quite large.
The car modules shut down in stages over 30-40 mins when working right so early measurements aren't much use.
This is all on existing threads... with lots more...
Dagny
Jun 11, 2024 01:06 PM
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
captbob73
Oct 24, 2015 05:49 PM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
DEklof
Sep 8, 2015 05:28 PM
