Battery Failure Explanation?
Old Jun 6, 2014 | 01:04 AM
JagV8's Avatar
JTIS quotes that with a battery voltage not below 12.5V, on a high rate discharge test (applying a load of 300 Amps) then battery voltage should not fall below 9.6 volts at a temperature of 21 degrees centigrade (seventy degrees fahrenheit).
JTIS says to charge the battery if it's not at least 12.5V.
On battery temperature increasing after a 10-min drive, I suspect it won't as it's in the boot (trunk) and won't change worth mentioning in that time.
No mention of ripple etc in JTIS. But I quite like the idea that this could be an extra way to condemn a battery since changing the battery is a fix so often.
Bearing in mind the regulators fitted in each module (they tend to be 5V or 3.3V logic) I don't see any way that a few hundred mV of a/c ripple could cause any problems.
Forcedair1
Sep 8, 2025 01:57 PM
99xk8guy
May 28, 2024 09:36 PM
Jandreu
Sep 20, 2015 08:20 AM
mrobinson
Sep 18, 2015 07:20 AM
Tim Goz
Sep 17, 2015 09:11 AM
