BATTERY HELP!
Old Dec 20, 2008 | 05:31 PM
whiteSTR's Avatar
Default RE: BATTERY HELP!
You may have too much corrosion on the terminals or cables, or it could be a problem with your starter/solenoid.. there are a plethora of problems that would cause exactly what your talking about.. Any other details?
Old Dec 20, 2008 | 10:23 PM
Brutal's Avatar
you probobly need a fuel pump, I just put a pump in an XJ8 this afternoon for the same problem, crank it and check for fuel pressure on the fuel rail by depressing the shrader valve with a small screw driver, no pressure. replace the pump. You access it by pulling up the back seat, pop out the black rubber/plastic round panel under the passenger side rear seat. And you see where you need to remove the fuel tank access cover.
Msteiner
May 16, 2016 12:19 AM
jluckcuck
Nov 6, 2015 07:49 AM
10 XF Premium
Oct 2, 2015 09:22 PM
Swagguar
Sep 30, 2015 01:34 PM
