Battery Light on
Old Aug 1, 2016 | 07:53 AM
Carlg07's Avatar
Default Battery Light on
05 STR
the Battery light went on this morning as i started the engine. No messages just the red light.
the power steering was not working but everything else seems to be working
any ideas?
Old Aug 1, 2016 | 07:59 AM
jimbov8's Avatar
You could charge the battery on the off chance that it is low.
Measure the voltage across the battery with the engine running, should be around 14.1V.
Old Aug 1, 2016 | 08:25 AM
kr98664's Avatar
The loss of power steering is a big clue. Did you look under the hood? Is the serpentine belt still intact? Is the belt still tight?
A broken or slipping belt would take out the alternator and power steering at the same time. You'd also lose your air conditioning, but you may not have noticed that on a cool morning.
Old Aug 1, 2016 | 09:20 AM
Carlg07's Avatar
I went out and ran the car letting it warm up for 20 minutes. Battery light went off, power steering came back all gags normal, no messages.
has me confused.
power steering fluid just under max.
I am baffled.
Taking it to the mechanic for a check, of belts.
i will let you know results.
Old Aug 1, 2016 | 09:52 AM
dlowings's Avatar
has me confused.
I am baffled.
I wonder if your battery is about to give up the ghost, perhaps the amps dropped over night but when you ran it for 20 min the alternator was able to bring it back up to par for a while ?
Old Aug 1, 2016 | 10:04 AM
Mikey's Avatar
This. Get the belt or it's drive fixed before you get stranded.
Old Aug 2, 2016 | 11:31 AM
Carlg07's Avatar
I have to believe that the battery is the cause.
its in the garage getting checked out, i will let you know the results.
thanks for the help.
Old Aug 2, 2016 | 12:19 PM
Mikey's Avatar
Explain the loss of power steering........
Old Aug 4, 2016 | 10:12 PM
kr98664's Avatar
Its in the garage getting checked out, i will let you know the results.
Any word yet? What did the shop find?
Old Aug 6, 2016 | 08:28 PM
Carlg07's Avatar
Shop found battery was ok belts ok nothing sticking. I questioned one of the tension units and everything was operational and working.
I guess the no answer is the good answer for now. Time will tell
Old Nov 2, 2017 | 10:01 AM
Carlg07's Avatar
Found solution to power steering not working. the belt tension was not working all the time. replaced that and new belts while doing it everything is working fine new.
Old Nov 2, 2017 | 06:33 PM
aholbro1's Avatar
Hmm....intermittent failure of the belt tensioner? That's novel. Are you absolutely certain? I'd be dubious of the crank damper...
Old Nov 4, 2017 | 12:14 PM
abonano's Avatar
+1 especially with the temporary loss of power steering.
loftymk1
Apr 18, 2016 05:18 PM
fastlanz
Apr 7, 2016 09:13 PM
bigbigbrig
Apr 4, 2016 08:21 AM
daves_ale
Mar 28, 2016 02:05 PM
Jagg
Mar 16, 2009 08:46 AM
