Best year for the S Jaguar?
Old Aug 11, 2021 | 03:00 PM
Dante1's Avatar
Default Best year for the S Jaguar?
I love my 2005. Now have 160,000 miles and drives beautifully. Looking for another and wanted some feed back on best year etc.
dante1
Old Aug 12, 2021 | 03:31 AM
M-e-l-l-o-w's Avatar
Appearance is a bit subjective when it comes to the updates.
Personally I think the 05-model year update looks better, but others like the older look.
There are other minor advantages with the 05 update, like the aluminium hood, before that they were steel.
The 05-model year updated cars made from January 2004 also use the Jaguar SDD software that is better than the previous Jaguar IDS software and is easier to set up as well.
In addition the head units are fully 'open' so that any additional items added on the d2b network, like a CD changer for example will just work on a 'plug and play' basis.
In regard to the STR I also think that the Vulcan wheels used on the 05MY and 06MY cars look a lot better than the Zeus wheels on the previous STR's. The Brembo brakes look better than the later ATE brakes that were introduced for the 06 model year cars, but the later are supposed to work better, however in normal road use there is no difference.
In the UK STR cars registered on or after 23rd March 2006 have a £590 annual road tax, before that date the STR’s are a lot less at £330 a year. But you are in the US, so this will not be an issue for you.
In the US it would appear that there are a lot more pre-05MY update cars than later ones. This may make them harder to find and also make it harder to find parts that are specific to the later cars.
Mellow
Old Aug 12, 2021 | 07:59 AM
Dante1's Avatar
Default Thanks Mellow
Mellow,
Thanks for the response. I read it twice to digest your thoughts and opinion.
Mine are similar..
Thanks,,
Dante1
Old Aug 12, 2021 | 08:28 AM
kr98664's Avatar
Mellow made some good points, but there are also some factors in favor of the earlier models.
The later models have an electronic parking brake, which seems to be a recurring problem on the forum. They are very sensitive to low prestart voltage from the battery (even if the starter works fine), and will often set a warning message. The other issue is the actuator motor and gearbox are prone to corrosion damage, and the cables get bound up. The earlier models have a much simpler lever operated handbrake, perfect for those of us who learned to drive by watching the Rockford Files:
Big changes with the transmission, too. The earlier models use a 5R55N 5 speed, a variant of a common Ford transmission of which several bazillion were built. Any competent transmission shop can handle any repairs, hopefully at a reasonable cost. Later models have the ZF 6HP, a much more advanced unit but generally more expensive to repair.
Another consideration, and this has been scientifically proven, is that owners of the early model are much smarter than late model owners. The difference is astounding, by approximately 30 IQ points. Early model owners smell nicer, too.
Old Aug 12, 2021 | 08:48 AM
The Voices's Avatar
Smile
https://www.youtube.com/watch?v=5X7XGmS6Pe4
I have only one thing to say.
Which is:
Good points about the earlier cars, but alas, no S-TYPE R !
Old Aug 12, 2021 | 09:37 AM
Coventry Foundation's Avatar
There are some that would say the 1964-1967 models! Just saying.
Old Aug 12, 2021 | 02:21 PM
Dante1's Avatar
Default 2005 S Jaguar 3.0 pigtail
My question, is there a Ford 2 wire pigtail Throttle body connector that will fit my 2005 S ?
Old Aug 14, 2021 | 11:53 AM
max224's Avatar
aLet's not forget that the early 4.0L engines had a chronic problem with their plastic timing chain rails which led to catastrophic engine failures. Supposedly, the problem was limited to engines manufactured prior to August 13, 2001, but I have no definitive information confirming that. When in doubt one of the cam covers should be removed to visually determine whether the upper chain and tensioners were replaced.
Old Aug 14, 2021 | 12:12 PM
joycesjag's Avatar
Hands down 2005 MY, everything after is hodge podge of getting rid of inventory before the end of our beloved S Types.
Old Aug 16, 2021 | 12:29 AM
xalty's Avatar
06 has better brakes and a better PCM
Old Aug 16, 2021 | 11:17 AM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Talking
ROFL!
Old Aug 18, 2021 | 08:23 AM
wydopnthrtl's Avatar
03+ w/4.2L V8 & ZF 6 speed gets my vote
Old Aug 18, 2021 | 11:41 AM
JagV8's Avatar
I prefer the shape before the front was changed (05 / 06) and like the car better with no chrome (so I don't like the daft rear strip added 05/06), and of course like the ZF 6HP26 and V8.
So, 03 / 04 and STR please. (04 STR is what I bought.)
Old Aug 18, 2021 | 02:02 PM
Dante1's Avatar
Default 03+ w/4.2L V8 & ZF 6 speed gets my vote
Thanks for your response. I'm looking a 2nd S and your reasoning helped me.
Dante1
buickfunnycar.com
Nov 9, 2016 11:08 AM
retriever-007
Jan 4, 2016 04:29 PM
2ndxk8
Apr 13, 2012 10:57 AM
hiliters1975
Dec 12, 2010 07:33 AM
Mikey
Apr 7, 2010 07:15 PM
