Bleeding brakes and changing caliper on STR
Old Sep 29, 2012 | 05:28 PM
FJG123's Avatar
Default Bleeding brakes and changing caliper on STR
Hi there
I have an 2004 STR with leaking seals on front drivers side caliper.I have just picked up a nice looking used caliper.i notice that there are two bleed screws on the caliper.Which do I use to bleed with and what is the order for brakes?
-Also notice that JTS says I am supposed to use new caliper bolts and sealing washers?Is this necessary or can i reuse the old ones?
Thanks.Fitz
Old Sep 29, 2012 | 05:34 PM
If the original caliper has one bleed screw and the one you've 'picked up' has two, it's the wrong caliper for your vehicle.
Old Sep 29, 2012 | 06:37 PM
QuartzSTypeR's Avatar
You should be ok with reusing the old bolts/washers. It wouldn't hurt to put a little locktite on them though. Are you sure there are two bleeder screws, and not one bleeder and another spot where the brake line goes in?
Old Sep 29, 2012 | 07:37 PM
Michael Star's Avatar
Ya when I changed my fluid I only saw one bleed screw. Pick up a vac bleeder while you are at it to make it easier.
Old Sep 29, 2012 | 09:42 PM
FJG123's Avatar
Thank you everyone
I think the second bleed screw is on the back of the caliper.
1-Do you folks recommend using the backing plate grease on the back of the backing plate where the pistons meet the pad?
2-Do you recommend using synthetic lubricant on the slider pins after cleaning the rust off?
3-How do you cap the caliper brake hose when removed to change the caliper?
Thanks everyone.
Old Sep 30, 2012 | 10:49 AM
clubairth1's Avatar
Community Influencer
Yes you have two bleeders on each caliper. Check that they are facing forward on the front brakes. Straight up on the rears. Be sure and do them one at a time or you are only bleeding 2 of the 4 pistons.
See picture of front caliper below.
Attached Thumbnails Bleeding brakes and changing caliper on STR-brembo-front-caliper.jpg
Last edited by clubairth1; Sep 30, 2012 at 11:18 AM. Reason: Hit wrong button. Sent too soon!
Old Sep 30, 2012 | 06:18 PM
I just went out to my car to check, and you are definitely 100% correct! I've learned something new today; I don't think I've ever seen a caliper with 2 bleeders before. FJG123, just make sure the bleeders are on the top when installed.
Forcedair1
Sep 8, 2025 01:57 PM
H20boy
Dec 24, 2024 03:23 PM
PMKimpton
Aug 3, 2019 08:22 PM
philwarner
Sep 5, 2015 10:05 AM
