Body conversion
Old Dec 11, 2018 | 02:03 PM
stancage's Avatar
Default Body conversion
Hi, i have a simple question about the body of the s-type
Is it possible to exchange the hood, bumper and wings of the phase II with phase III ones ?
your humble servant,
J.
Old Dec 11, 2018 | 02:10 PM
Mikey's Avatar
What is phase II and III?
Old Dec 11, 2018 | 02:17 PM
scottjh9's Avatar
Do you mean pre and post facelift..aka 2002.5 and newer vs 1999. Or 2002.5 vs 2005 and newer...
Old Dec 11, 2018 | 04:20 PM
stancage's Avatar
exactly, i have a 2002 witch is destroy and it came to pass that some guy proposed me his 2006 body
Old Dec 11, 2018 | 06:03 PM
joycesjag's Avatar
Preface lift to post face lift not as easy as swapping parts but, ANYTHING is possible with alot of bondo!
Old Dec 11, 2018 | 06:12 PM
scottjh9's Avatar
I am pretty sure the items you want to swap are the ones that got redesigned from 2002.5 onwards . So direct fit on the bumpers is a no and I believe the hood also a no. I am not a body expert but with some mods they probably would...there are many very sharp minds on here so I am sure you will get more detailed advice than mine
Old Dec 11, 2018 | 09:27 PM
joycesjag's Avatar
He did in post #5. The entire front end panels are not interchangable without a lot of bondo any more money than sourcing correct parts!
Old Dec 12, 2018 | 05:46 AM
stancage's Avatar
guys this looks very promising
you talk about money but bondo is not that expensive !
Old Dec 12, 2018 | 07:10 AM
Panthro's Avatar
IIRC, when this subject came up before the general consensus was that the front fenders, bumper cover, & hood would be required at least. Not sure about the front bumper mounts. The rear bumper was an unknown, but you'd probably need the trunk lid. That would mean that a tail light swap would be needed too since all that stuff changed shape with the facelift. That would also mean modification of the rear fenders, which means bodywork (welding and/or bondo). None of this is proven, so if you did attempt this sorta thing you'd definitely be the 1st. Sounds kinda expensive for an experiment tho. This info is worth exactly what ya paid for it, and as always YMMV. Good luck if you try it
Old Dec 12, 2018 | 08:24 AM
joycesjag's Avatar
Many, many years ago, a fellow members did in fact try to match up a post face lift on a preface lift S Type. He took 1 picture of the vehicle while sitting under a carport out west ssomewhere. Mostly post face lift parts were different colors, obviously from different donors. The hood was preface lift. Nothing matched up!
I have mentioned this several times over the years. Unfortunately I have tried and tried to find that post without any luck.
Old Dec 12, 2018 | 10:52 AM
stancage's Avatar
many thanks
i read in this thread that the front fender (wings) apparently doesn't changed after the 2004 face lift
this could be interesting but it appears to me very wired that the bumper and the hood changes without the wings...but maybe ?
this is getting very exciting. i know that doesnt change alot for many but i feel the 2004 face lift way more appeling
Old Dec 12, 2018 | 12:02 PM
JagV8's Avatar
It may be right but I don't know for sure. Check the part numbers - if they changed then they're likely different.
Old Dec 14, 2018 | 03:14 PM
stancage's Avatar
hey guys i just thought that it would be nice if the bumper wings and hood of the str (supercharged) version could be mounted on the 2002 classic version ? do you know if it's possible ?
Old Dec 14, 2018 | 03:50 PM
JagV8's Avatar
Check all the part numbers.
booklaw1
XE ( X760 )
Mar 31, 2018 06:49 PM
Serlock
Sep 27, 2017 03:49 PM
bull of pits
May 12, 2015 01:25 AM
XKRacer
Oct 21, 2010 06:23 AM
