brake booster vacuum line clip
Old Mar 25, 2013 | 08:41 AM
dtown_50187's Avatar
Default brake booster vacuum line clip
2004 s type r, anyone have a part number on the round plastic clip on the engine side of the brake booster line. mine broke. my jaguar parts guy having trouble. thnaks
Old Mar 28, 2013 | 04:26 PM
xjrguy's Avatar
I think you can get some parts to fix that vacuum pipe with P/N C2S15816. That is not listed anywhere for the V8, but I'm pretty sure the "O"ring and the black collar from that kit can be used for your car.
Good luck!
Old Mar 29, 2013 | 01:15 PM
Default vacuum clip
i called terry's jaguar in kalamazoo mi and had the part. this is exactly what i neede thanks xjrguy
Old Mar 29, 2013 | 01:45 PM
xjrguy's Avatar
Cool! Glad to help. Guess us dealer blokes are good for sumpin'!
Old Jun 2, 2013 | 10:05 PM
Robert Page's Avatar
My o ring for the vacuum line in the throttle body elbow needs replacing and my dealer says that the black plastic clip will break if they try to replace it, it sounds like the same problem that dtown was having. My dealers says that the part number C2S15816 is for an XType and will not fit my 2004 XJR because the plastic part is too small mine is bigger and Jaguar do not supply that kit for the XJR so it's new Elbow assembly needed at $1200. Now this plastic clip is separate from the Elbow so you must be able to get it surely. Any help would be greatly appreciated.
Old Jun 2, 2013 | 10:39 PM
xjrguy's Avatar
I know your dealer guy is sincere in his belief, but that's because the parts catalogue does not show that part listed for any engine but the V6's. The black collet and "O" ring in that kit will work for the vacuum pipe in your induction elbow. I have repaired numerous leaks at the booster pipes using that fitting kit. If I'm not mistaken, I think I've used it on the AJ16 engine as well.
Good luck!
Old Jun 3, 2013 | 04:12 PM
XJR thanks for that, I am positive that you are right. My dealer still is saying no so I will try to find out what the diameter of the booster hose is and try to prove to them it will fit the clip. Thanks again for the information it's great that we have access to guys like you.
clubairth1
30
Sep 3, 2025 04:38 PM
silkcat
Jan 18, 2025 04:29 AM
Bcrary3
Feb 21, 2023 04:29 AM
explorer364
Sep 11, 2015 05:44 PM
1964Daimler
Sep 9, 2015 11:28 AM
