Brake Fluid Low light
Old Aug 1, 2007 | 12:32 AM
badmojo's Avatar
Default RE: Brake Fluid Low light
Make sure that the pads are not dragging. It is a problem with some of the s-types. My rear wheels are allways filthy with brake dust, the rears!
Old Aug 1, 2007 | 12:36 AM
bigdreams05's Avatar
Yeah, but wasn't it your e-brake that was sticking? The 4.2 doesn't have a separate e-brake caliper like the R!
Old Aug 1, 2007 | 10:10 AM
badmojo's Avatar
I'm going to say that it is both. I manually turn of the parking brake now just incase and with all that dust I would have no pads or rotors left if it was just my parking brake. I have to wash my rear wheels 4 times to every 1 time I have to wash my fronts and the fronts are still very clean before washing and the backs are black! But of course THERE'S NOTHING WRONG WITH THEM.
Old Aug 1, 2007 | 12:25 PM
ken@britishparts.com's Avatar
First thing is check your fluid. If the pads are that low, it could cause the light. You may also have a faulty switch.
Old Aug 2, 2007 | 08:40 AM
Ahhh! This post made my day! I love it when newbies actually come back and say thank you and keep us posted! You get a medal of honor RP!
Old Aug 2, 2007 | 06:38 PM
cap79's Avatar
If u bought ur car brand new and it has less than 12000 miles and
less than one year since u bought it, it has to be cover under warranty. premature wear. must have parking brake motor
seized, causing premature wear.
Old Aug 8, 2007 | 10:13 AM
badmojo's Avatar
Brake pads are cheap and easy to install. It's the other issues that the dragging pads cause that are the problem. All the damage caused by the eccessive and constant heat. Warped rotors, Burned out wheel bearings and over heated calpiers that can cause the seals to go bad leading to possible brake failure. They need to fix the problem not just keep installing new pads!
Forcedair1
Sep 8, 2025 01:57 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
afterburner1
Dec 16, 2015 12:12 AM
jdzubas
Oct 4, 2015 09:14 AM
