Brake Fluid Type for my 2005 S-Type
Old Oct 19, 2010 | 06:59 PM
micsteam's Avatar
Default Brake Fluid Type for my 2005 S-Type
I just bought a 2005 S-Type base model and don't the manual, does anybody know what type of brake fluid this car requires ?? Dot 4 ??
Old Oct 19, 2010 | 07:05 PM
vance580's Avatar
Dot 4 is correct.
Old Oct 19, 2010 | 08:39 PM
Dirk Bailey's Avatar
Welcome,
I'm about three weeks ahead of you. I just bought an 05 stype base model...my first Jag. If your new to this site you're going to be pretty blown away by all the knowledge and support you'll receive. I thought I'd give you a quick list of things I manage to fix/replace with the help of this site. Sure enough my coolant tank leaked at the top nipple (within a week of buying it) replaced it in 15-20 minutes. Replaced the cabin filter easily after viewing the video. You may not gain access to all parts of this site initially but eventually you should. My steering wheel squeeked (or so I thought) until I looked around the forums and discovered that the power steering pump radiates a sound up the steering column and 50ml of additive will get rid of the noise. They were right on and I'd a bet money it was coming from the wheel. I've ordered solid one piece lugs to replace the stock two piece lug nut.
If you've searched brake fluid and bleed brakes you'll find a ton of advice. I too have got brake fluid on my list. Let me add this, the 05 or maybe the 06 was the last year Jag performed free maintenance until 2010. So depending on your mileage and your routine services it may be your brake fluid is not that old. Jag says every two years but I've read 2-3 years is fine.
Best of luck with your "new" ride and enjoy this site.
-db
"the beatings will continue until moral improves"
Old Feb 23, 2011 | 07:23 AM
micsteam's Avatar
Thanks Dirk, sorry for the long time in reply. Just the simple pointers from some of the problems you've experienced has solved some of the head scratchers I've discovered with my car. Thanks again and I look forward to using the site.
Old Feb 23, 2011 | 08:51 AM
joycesjag's Avatar
To help with more of your head scratchers later, you should put in your signature details of your vehicle: year, model and engine!
Old Feb 23, 2011 | 09:30 AM
Gus's Avatar
Gus
Hello and welcome to jaguarforums.com. I know that you are anxious to get started and we are anxious to meet you and talk about your car. We have a baseline / criteria that must be met before full access can be granted. Please enjoy the forum and be patient once the baseline has been satisfied full access will be granted. Please continue to post and accept my welcome to the forum.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
niner nellie
Sep 1, 2015 10:53 PM
nelsonht
Aug 30, 2015 06:01 AM
dpappyp
Aug 27, 2015 06:31 AM
