Brake flush need to be done when replacing front rotors and pads?
Old Sep 19, 2013 | 01:00 PM
daboss085's Avatar
Default Brake flush need to be done when replacing front rotors and pads?
Does anyone know if a brake flush needs to be done if doing the front rotors and pads. Both pads and rotors will be new and replaced. A Jag tech in my area said he would never change brakes on the jags without doing a flush. I did a brake flush on the car at the dealer about 4 months ago, so IDK what do you guys think?
Old Sep 19, 2013 | 01:04 PM
tbird6's Avatar
No. But your car is over 11 years old. You should swap the fluid out sometime and when changing brakes you are right there anyway.
I always do a flush along with the brake job. It's just the proper time to do it.
police666's Avatar
I wouldn't bother, but if it gives you peice of mind you can.
Old Sep 19, 2013 | 01:36 PM
Mikey's Avatar
There's no technical reason to do a flush when doing pads. Ask your guy why 4 month old fluid is no longer serviceable.
Old Sep 19, 2013 | 02:30 PM
JagV8's Avatar
4 months old fluid - great. No flush for me if I were doing the job.
That said, last time I did the job I did a flush, but my fluid was much older.
Old Sep 19, 2013 | 03:25 PM
daboss085's Avatar
yeah figured thats since I had it done 4 months ago from the dealer. And with slotted/Drilled rotors from power stop need to be bedded in properly correct?
Old Sep 19, 2013 | 04:15 PM
JagV8's Avatar
I avoid slotted & drilled rotors.
Old Sep 19, 2013 | 05:59 PM
daboss085's Avatar
really, how come??
Old Sep 19, 2013 | 06:12 PM
Mikey's Avatar
Originally Posted by daboss085
really, how come??
NO advantage in stopping power on street driven cars. Some can be noisy making 'swish' sound. It's bling thing only.
All pads and rotors need to be bedded in.
Old Sep 20, 2013 | 06:23 AM
police666's Avatar
+1 had cross drilled rotors (discs in uk) on a previous car, so much noise I changed back to stock.
Old Sep 20, 2013 | 11:49 PM
sprdav33's Avatar
I would only flush the fluid if it's been over 5 years. Let me know how those brakes work for you. I've been thinking about putting them on my car.
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
ronald4313jm
Aug 31, 2015 07:58 AM
souldoubt
Aug 25, 2015 08:15 PM
