Brake job today
Old May 16, 2021 | 09:26 AM
Scotlad's Avatar
Default Brake job today
Doing the front brakes today on my 2005 STR and was wondering if I should put anti seize on the big caliper bolts when I put it back together? I think I will do the fuel filter also while I have the wheel off. Great video on U tube from Vance on how to do the fuel filter. I decided to go with Centric rotors and pads from Rock Auto.
Old May 16, 2021 | 11:20 AM
joycesjag's Avatar
I put antiseize on brake bolts.
Yes Vance is da' man!
Old May 16, 2021 | 08:59 PM
Scotlad's Avatar
Well I got the front brakes done and one problem I had was the hardware kit that came with the front brake pads. When I opened the package I thought great, it comes with new pad retainer pins and new flat spring plates (Brembo brakes).The problem with the pins was that there is a little split bushing that is supposed to be knocked into the caliper that holds them in place. The bushings were made oversized and would not go in. The spring plates were made with wings (that hold the pads down) that were too narrow. I ended up wire brushing the original pins (which were a much higher grade) and using the old spring plates. Sometimes oem is the way to go.
The fuel filter took me a while to get off the fuel lines even though I had just bought the disconnect tool. Maybe the fittings were a little sticky if it had not been changed in a while. Vance on U tube made it look so easy!
Old May 17, 2021 | 01:40 AM
JagV8's Avatar
Sounds like they were probably Brembo but not the right Brembo parts.
Old May 17, 2021 | 08:49 AM
Scotlad's Avatar
The hardware was actually Centric brand that came with the Centric front brake pads. The original Brembo pins were nicely machined the replacements were not.
Old May 17, 2021 | 07:08 PM
jya's Avatar
jya
Fine to reuse the originals I found.
Biggest problem I had was when I removed the main, large calliper bolts I found the internal alloy threads were damaged..
It's possible it was the anti seize..
Old May 17, 2021 | 08:27 PM
Scotlad's Avatar
Something else I noticed about the original pins was that they were machined smaller in the middle and this "grove" centered the flat spring plate. The generic pins that came with the pads were not machined in the middle and if they had worked, you would have to center the spring manually.
I went past my mechanic today to make an appointment for an oil change and to have the rear brakes done. He lets me bring in all my own parts, great guy, works on Euro cars only. I mentioned the trouble I had getting the filter off even using my new disconnect tool. He agreed they can be a problem and gave me a couple of tips. If they are are sticky he blows out the fitting with compressed air and sprays a little lube or maybe penetrating oil in the connection. He said they can get dirt and or rust in the connection.
Scotlad
Jan 10, 2021 01:16 PM
vance580
28
May 15, 2017 06:43 PM
Trevor
Nov 3, 2014 04:16 PM
Jon89
Aug 16, 2011 06:53 AM
hottienamedscottie
Apr 16, 2009 08:56 AM
