Brake/steering wheel shudder
Old Aug 31, 2016 | 05:24 AM
Tink's Avatar
Default Brake/steering wheel shudder
With normal city driving, not every time but often, when a soft application of the brake pedal is made to slow down the car there is a slight shudder through the front wheels and a small shaking of the steering wheel. Pressing the brakes more firmly stops this but it is usually more braking than is required in most situations. Also a couple of light touches on the brake pedal before actually braking can stop it from happening. When doing country driving the issue is more severe after travelling for awhile and it takes a couple of dabs on the brakes to reduce the shaking before applying more braking effort to make the shudder go away.
Any thoughts out there. Because it is not a constant issue my initial thinking is maybe something to do with the ABS or brake pads and not the rotors, but I am not a mechanic. Thankyou, Tink
Old Aug 31, 2016 | 06:46 AM
JagV8's Avatar
Sticking caliper piston(s) / warped rotor(s) / loose suspension. Any good mechanic should be able to diagnose & fix it.
Old Aug 31, 2016 | 09:55 AM
Tink's Avatar
Thanks, I will get it checked out soon on the next service.
Old Aug 31, 2016 | 10:19 AM
Mikey's Avatar
A very common issue. The rotor surface is probably contaminated with residue from the pads. An abrasive wheel will remove it.
Old Aug 31, 2016 | 07:41 PM
Tink's Avatar
I will check the rotors out soon. Cheers.
fresno
May 11, 2016 12:34 PM
rfr66
Apr 20, 2016 09:16 AM
Gondolaboy
Apr 17, 2016 07:30 AM
brickkop
XJ40 ( XJ81 )
Jan 25, 2008 09:03 PM
H20boy
Dec 18, 2007 08:22 PM
