Broken Key - 2005 S-type
Old Jul 30, 2017 | 06:53 PM
RBSJAG85's Avatar
Default Broken Key - 2005 S-type
I recently broke the key for my 2005 Jaguar s-type off in the ignition. It has completely broken free from the remote. I was able to start the car by turning the key with a pair of pliers; however, since driving it home, it will not start. All of the accessory lights come on but when I turn the key there is absolutely no engine cranking. I tried holding the key fob close the the ignition while turning the key but still nothing.
Old Jul 31, 2017 | 02:23 AM
JagXSE's Avatar
Why post on X Type forum not the correct one?
Old Jul 31, 2017 | 04:03 AM
Welcome to the forum,
I've moved your post to the S Type forum for a better response.
If you had posted in the new members area you would have been directed to the correct area.
Old Jul 31, 2017 | 04:37 AM
JagV8's Avatar
I think it'll be necessary to take the column etc apart, then extract the lock / key. Be gentle.
Old Jul 31, 2017 | 09:05 AM
clubairth1's Avatar
Community Influencer
I think so too.
Can you do the repair yourself?
Do you have the shop manual? It's called the JTIS and it's free on this forum.
You will need it.
Old Jul 31, 2017 | 09:26 AM
motorcarman's Avatar
The steel piece of key does not have the transponder in it. Use another key that is complete (please don't say you only have one key).
Another way is to turn the metal key with pliers but hold the plastic part that broke near the key as you crank it (it has the transponder in it).
bob
Old Jul 31, 2017 | 10:14 AM
clubairth1's Avatar
He said he held the FOB up so that should get the transponder close to the ignition switch.
Maybe a battery problem with the FOB?
kr98664
55
Jun 17, 2025 02:36 PM
clubairth1
Aug 17, 2017 08:40 AM
Jagger62
Aug 3, 2017 08:21 AM
weddingjaguars
Jul 20, 2017 07:44 AM
Joshua Silva
Jul 18, 2017 04:53 PM
