A/C compressor 2001 3.0 swap DIY cost
Old Jan 30, 2011 | 08:52 PM
01stype30's Avatar
Default A/C compressor 2001 3.0 swap DIY cost
(Refurb) A/C Compressor with clutch = $102.00 Ebay same compressor as Lincoln LS
115VAC 2.5 CFM vacuum pump = $104.00 Harbor Freight A/C compressor 2001 3.0 swap DIY cost-100_8717.jpg
R134A Gauge set = $40.00 Harbor Freight A/C compressor 2001 3.0 swap DIY cost-100_8712.jpg
3 cans of freon approximately $60.00
Total cost to DIY approx $306.00. Vacuum pump and gauge set can be used on any car using R134 freon.
Attached Thumbnails A/C compressor 2001 3.0 swap DIY cost-100_8723.jpg
Old Jan 30, 2011 | 09:03 PM
joycesjag's Avatar
very nice 01!!! Great info
Old Jan 31, 2011 | 01:26 AM
JagV8's Avatar
Where did the gas go that you vacuumed out?
Old Jan 31, 2011 | 08:36 AM
androulakis's Avatar
Good Job bud! Told you you could do it!!
Take care,
George
Old Jan 31, 2011 | 09:24 AM
01stype30's Avatar
You should get the 134A evacuated from the system before removing the old compressor. A local garage charges $60.00 to evacuate. I pulled a vacuum on the system for 30 minutes after removing and installing the new compressor.
It should be noted by DIY the warranty on the refurb compressor becomes void. I weighed my options and took my chances.
I have pictures of the High and Low ports if anyone is interested.
A/C compressor 2001 3.0 swap DIY cost-100_8718.jpgHigh side port located by the receiver drier.
A/C compressor 2001 3.0 swap DIY cost-100_8719.jpglow side port located at the compressor.
Also I want to apologize for not documenting the whole job. The next time I do a job I will take pictures and document everything so I can post.
Old Jan 31, 2011 | 09:28 AM
Attachment 7642High side port located by the receiver drier.
Attachment 7643low side port located at the compressor.
IF you have a warranty issue with the compressor let me know... I'll take care of it.
Take care,
George
Old Jan 31, 2011 | 09:41 AM
01stype30's Avatar
If you look at the gauge set picture you will notice styrofoam by the lid cylinders. These were needed because the gauge set weighed the lid down. It didn't pull the lid down imediately but it came down and about mashed my fingures.
Rivguy
Dec 4, 2020 07:55 AM
Dicque
Sep 19, 2015 12:53 PM
skadmiri1
Sep 9, 2015 11:27 AM
Corycarlo
Sep 5, 2015 11:41 AM
d a
Sep 3, 2015 02:34 AM
