A/C orface tube and dryer
Old Jul 4, 2018 | 04:16 PM
Phydeaux1's Avatar
Default A/C orface tube and dryer
2007 S Type. AC system readings are indicating a blockage. Can anyone tell me where the A/C orface tube and dryer element is located on this car? I can usually find them, but not seeing them. Thx..
Old Jul 4, 2018 | 05:41 PM
kr98664's Avatar
No orifice tube on the S-Type AC. There is a thermal expansion valve instead. It’s located center of the firewall, directly behind the engine. Never messed with mine, but supposedly it’s a bear to change, requiring tearing apart the dash. Hopefully your problem lies elsewhere.
I’m not sure where the dryer is located on the late model cars. Maybe somebody in the know will chime in.
Old Jul 4, 2018 | 10:15 PM
Phydeaux1's Avatar
Yes I saw the expansion valve, I didn't notice a bolt(s) allowing removal from the firewall side. The dryer is not in the usual locations up by the condenser, I lose sight of the low side line behind the drivers front wheel well from inside the engine compartment. I will have to get under it and see if it gives me a view of what I can't see from above, it may be hiding back there somewhere. But if anyone knows for sure, would appreciate letting me know. Thx..Wolf.
Old Jul 4, 2018 | 11:03 PM
Phydeaux1's Avatar
After a long search I found this on another thread, but it was regarding a 2005, I will look to see if its the same on a 07. Never seen a AC dryer like this.
The dryer is a bit of a head scratcher and it's just a fabric desiccant bag. Look on the passenger side of the A/C condenser and you will see a small black metal cylinder. At the bottom of this cylinder there is a large hex plug. Remove the hex plug and the bag can be pulled out with needle nose pliers. Then just slide the new bag in and recap. The difficulty is getting to underside of that cylinder!
Old Jul 4, 2018 | 11:36 PM
NBCat's Avatar
Refer to page 2647 of the Workshop Manual for the location of the desiccant bag:
https://www.dropbox.com/s/aq3872pbu5...kshop.pdf?dl=0
Last edited by NBCat; Jul 4, 2018 at 11:38 PM. Reason: Correct spelling of 'desiccant'
Old Jul 5, 2018 | 09:23 AM
Phydeaux1's Avatar
Thank You!
davidladewig
17
Feb 6, 2017 07:47 AM
jcamayd
Jul 18, 2015 01:35 PM
EZDriver
Jun 20, 2014 02:51 PM
D. Fite
Jun 3, 2014 06:05 PM
lsuneworleans
Jun 30, 2010 04:35 PM
