Calipers and rotors
Old Feb 28, 2014 | 02:33 PM
desertchimera's Avatar
Default Calipers and rotors
Has anyone upgraded their rotors from 300mm to 326 mm? The rears are not a common rotor to find but the fronts (305 mm)are and every time I go to a brake site and add my car in the search, it always pulls up 326 for my model , year and type of vehicle. I have been talking with R1 Concepts but I have been told only Jaguar still holds the license for this particular 300mm rotor. The 300mm rotors are very costly from what I have found but I can get the 326mm for a fraction of the price. Since It seems the 326 mm rotors to be the common rotor online for my vehicle, it looks like I need to change my calipers out to accommodate the larger size rotor, question is has anyone had to do it, what parts are needed and what does it entail?
Old Feb 28, 2014 | 04:23 PM
Mikey's Avatar
???? I went to 2 or 3 sites. Each offers the choice of 300 or 320mm dia. at similar prices.
Try EBC
EBC Stock Replacement Rotors | EBC OEM Replacement Brake Rotors
Old Feb 28, 2014 | 04:58 PM
The site you sent me too is only the 326 mm rotors 12.8", that's for both front and back....that's the issue I am having....300 mm 12" is what I have.
Old Feb 28, 2014 | 05:02 PM
I am also wanting more than standard rotors, I want them drilled and diamond slotted with zinc or chromium plating to prevent rust.
Old Feb 28, 2014 | 05:04 PM
Second pic....my car is a 2008 jaguar s type 3.0 base model
Old Feb 28, 2014 | 05:18 PM
Mikey's Avatar
Actually, you probably don't want those. Slots and holes are pure bling and do nothing for stopping power in street useage.
Try putting model year 2005 in your search instead of 2008. Not sure if the parts are identical.
Old Feb 28, 2014 | 05:27 PM
This is the type rotor I am wanting for my car.
Old Feb 28, 2014 | 05:29 PM
These are the zinc plated ones
Old Feb 28, 2014 | 05:32 PM
2005 model are not the same ones, I have ask. Don't know what the difference
Old Feb 28, 2014 | 08:22 PM
GT42R's Avatar
brakeperformance.com will have what you want at the best price...
Old Mar 1, 2014 | 10:27 AM
Tried that site, only offer the fronts for my size rotors
Old Mar 1, 2014 | 10:33 AM
This is a photo of that site, only fronts listed and no rears, that's been my issue
Old Mar 1, 2014 | 11:35 AM
GT42R's Avatar
Indeed, i just checked... they don't seem to have any of the 326mm rear rotors...
Not sure what would be required to convert to 300mm rotors in the rear,
likely caliper brackets, maybe calipers themselves too, I'm not too sure what the electronic parking brake looks like on your car (I'm not very familiar with anything bu the R model brembo brakes on these cars)... does the EPB cable engage a 'drum brake' style mechanisim inside the rotor hat, or does it pull on a mechanical linkage attached to the caliper itself?
How much mileage on you car?
Generally, cars are pretty easy on their rear rotors, you may need pads, but your rotors should still be good to reuse, or at least machine.
Don't do the rear rotors if they really don't need doing.
kthrash
Feb 25, 2019 10:20 AM
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
millertic
Sep 30, 2015 08:11 PM
dmatthewman
Sep 30, 2015 10:10 AM
