Cam positioning sensor wiring
Old Apr 17, 2021 | 04:53 AM
ThumperDumper22's Avatar
Exclamation Cam positioning sensor wiring
So I’m putting my 05 4.2 back together no the only thing I do not have done is a repair on the left side cam positioning sensor connector.
will it hurt -the car to start it without? And also how to I fill and prime the cooling system? Do I just fill it up and run it for a while and recheck or what?
Old Apr 20, 2021 | 01:35 PM
clubairth1's Avatar
Community Influencer
It should run but it will set a code as you know. Planning on fixing it? No damage to the car.
I just fill and cycle the car from hot to cold several times and keep filling the top tank as needed.
Old May 7, 2021 | 01:31 AM
Ok next question there is a coolant return line that comes out from the bottom of the throttle body. Where does the line go? It likes starts out 1/4 and comes out 1/2
Where does the big end end up? Any help would be appreciated
Drew Davis
Old May 7, 2021 | 07:41 PM
scottjh9's Avatar
Drew Davis
not for sure, but there should be a nipple for it on the thermostat water manifold or perhaps under the intake manifold. That is where my 2 str hoses go. Maybe similar for your 1. On the parts diagram it shows a nipple underneath the rad hose connection on the thermostat cover
Old May 8, 2021 | 12:58 AM
JagV8's Avatar
You may be able to figure it from the workshop manual - it has various diagrams etc.
dmpsqrd
Mar 27, 2016 09:06 AM
adam699
Feb 23, 2016 02:55 PM
agirouard
Nov 20, 2013 05:21 AM
agirouard
Nov 19, 2013 04:57 PM
SirJag
Apr 3, 2011 08:44 AM
