CAN BUS Problems
Old Oct 18, 2016 | 05:03 AM
amicus's Avatar
Default CAN BUS Problems
I own a 2005 2.7D S Type with 97k miles on the clock. For the last few months after about 15 minutes driving restricted performance comes up. My local garage has changed one of the airflow sensors and now wants to change the EGR valves. I have agreed as quite often the OBD shows there is a problem here but yesterday when he checked the memory of the OBD the following codes (apart from the P codes)appeared U0121, U0155,U0103,UO101,U0104. All codes appear a "sporadic". I have recently changed the battery (apart from buying a CTEK charger) fearing that this was the cause. Any suggestions welcome not only by me but my local "garagiste".
Old Oct 19, 2016 | 03:10 AM
My only two experiences with French garagiste in Arras and Menton left me with the firm belief they should stick to hammering tractors.
For anything more than basic Pxxxx powertrain codes, your local garagiste is unlikely to have a compatible scantool to communicate with your Jaguar and the listed Uxxxx codes are therefore misleading.
The clue to the restricted performance should be in the Pxxxx codes.
My preferred approach to troubleshooting is to first read and record the DTC's then clear them. Next run the vehicle again and see which reset. The reason being that often DTC's can be stored or pending which are irrelevant to the problem at the time. Of course, a compatible scantool is essential as is using the Jaguar DTC listing and not a generic lookup.
Old Oct 19, 2016 | 05:14 AM
JagV8's Avatar
Also, simply changing the battery causes codes that then ought to be cleared if you care. Certainly ignore them unless you have an exceedingly good reason to pursue them.
JimC64
Sep 3, 2016 08:20 PM
spots123
Aug 30, 2016 11:40 AM
new2jag2016
Aug 27, 2016 01:02 AM
keelak
Aug 26, 2016 07:58 PM
laurie1965
Diesel variants - All models
Aug 26, 2016 03:11 AM
