Can DTCs be check from instrument panel?
Old Jan 24, 2013 | 09:00 PM
STRrr's Avatar
Default Can DTCs be check from instrument panel?
is this possible in my 2003 S type R? If so, how's it done? I searched, but couldn't find an answer.
Thanks!
Old Jan 24, 2013 | 09:02 PM
STRrr's Avatar
I have a basic code scanner, but it doesn't check transmission codes, or dtcs from other modules...
Old Jan 25, 2013 | 12:20 AM
sprdav33's Avatar
You can get the codes by going into the Engineering Test Mode.
Jaguar S Type Instrument Cluster Diagnostic codes
Old Jan 25, 2013 | 12:50 AM
STRrr's Avatar
Cool. Thanks. I'll try it out tomorrow.
Old Jan 25, 2013 | 12:53 AM
heima's Avatar
Don't get too distracted. I am sure more than a few fender benders were caused by the driver having too much fun with engineering mode.
Old Jan 25, 2013 | 03:16 AM
JagV8's Avatar
Bear in mind what you will see are the ones the IC has. They may be very old but in any case you typically want the ones the PCM now has.
Just get a cheap OBD tool such as elm327 - about $15.
trosty
26
Dec 18, 2022 06:40 PM
cissdm
May 3, 2016 06:02 AM
redrover41
23
Sep 25, 2015 01:33 PM
johndahlheimer
Sep 16, 2015 05:44 PM
AL NZ
Sep 4, 2015 08:39 PM
